Clean ass engine bay..
Post Mon May 12, 2008 4:08 pm
How is something like this achieved?!
No wiring/header tank or anything on view 8)
georob
Post Mon May 12, 2008 4:33 pm
Header tank etc in the boot , wiring stashed through the inner wings/ bulkhead.
Always wanted to do the same to my old Mk1 Golf, couldnt be assed with all the work though lol
shazE30
Post Mon May 12, 2008 4:39 pm
That is beautiful 8O
siddiqi1
BFG Zone Contributor
Post Mon May 12, 2008 6:11 pm
the VW scene are jolly good at that sort of stuff; and the VR6 engine is such a beauty, not only to look at but to listen to as well!
Post Mon May 12, 2008 9:10 pm
tonybtonyb
Post Sun May 18, 2008 11:43 pm
It's hiding underneath the car!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun May 18, 2008 11:45 pm
when the pic was taken they took out all the other bits, wait till u see it now there junk everytwhere :twisted:
Post Sun May 18, 2008 11:51 pm
:snigger:
harry_p
Post Mon May 19, 2008 4:27 pm
hide stuff :D
a lot change to a top fill radiator and junk th eheader tank, screen was bottle in the boot, or tucked inside a pannel somewhere, wiring look extended and run down the chassis legs and tucked away as much as possible or run under the engine and up.
a lot junk the heater and it's plumbing, simplify the coolant pipe layout etc.
then you neet to cut off / grind down and smooth out any unused studs and brackets, grind and fill pannel joins, fill any now unused holes etc
tbe a lot of the properly smoothed ones are little more than show cars, overheat, suffer from airlocks and leaks etc.
can look superb though.
i think on an e30 you could clean up the bay a lot just by rerouting the wiring that runs down the wings and moving the washer bottle somewhere. i started doing it on my metro, moving the battery to the boot, and running the wires on one side out through where the siderepeater wires usually go, and up allong between inner and outer wing, exiting when they were as close as possible to where they needed to go.
cheers,
harry
oze30
Post Sun Jun 01, 2008 10:12 am
Looks like a big dinky toy! I like it!
