Sideskirts:Are all fittings the same?
shane325i
Post Tue Apr 29, 2008 11:18 pm
Hey chaps,i have a set of se skirts on the touring at the mo but will soon be taking possesion of some tech 1 jobbies,will the fitting clips/locations be the same for both?I know i'll have to add a couple more holes as the tech 1's extend up the arches.Basically will it be a pop on pop off thing or is that wishful thinking on my part?
Shane :D
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri May 02, 2008 12:35 am
dont think so mate drop simon13 a PM think he will know :cool:
oakey
Post Fri May 02, 2008 1:31 pm
shane320ii wrote:Hey chaps,i have a set of se skirts on the touring at the mo but will soon be taking possesion of some tech 1 jobbies,will the fitting clips/locations be the same for both?I know i'll have to add a couple more holes as the tech 1's extend up the arches.Basically will it be a pop on pop off thing or is that wishful thinking on my part?
Shane :D
I dont have a clue if the holes in the sill will be in the correct place but your better off moving the poppers on the skirt to match the ones on the touring. Nelly will know.
You need to get the fittings for the extended parts of the skirts where they join at the front arch. They are very cheap and you only really need one for each arch. You can get away with bonding them to the body as opposed to drilling holes.
The bottom clips I think are different to the SE ones. May be worth seeing how much a set of these cost from Paul
Not pop off pop on I'm afraid :)
shane325i
Post Fri May 02, 2008 3:34 pm
Cheers chaps :wink:
BillyWiz
Post Fri May 02, 2008 7:07 pm
Whenever possible avoid drilling new holes in your car, you're giving rot an easy way in. Bonding adhesive is extremely strong and will make an excellent job, just leave it for a day with a little pressure holding the skirt in position (breeze blocks with a pillow in front work great for skirts, g-clamps along the bottom of the door opening etc). This is of course if the correct holes are not already there. If you get any adhesive on your paint use white spirit to remove it. Hope that helps.
shane325i
Post Fri May 02, 2008 7:34 pm
Cheers fella,most helpful :wink:
Alburglar
Post Thu May 15, 2008 1:17 am
got a pic of the se skirts. would be interested if they come with clips.
M42 - rightness! with proper 4.27 LSD
