Fitting component fronts
Post Fri Apr 11, 2014 6:56 pm
polsta wrote:
bss325i wrote:eBay item number 261434463255
Thanks for that , but what would I do look how short it is ? That's never going to be able to go from the stereo to the amp
Use It with your existing lead.
polsta
Post Fri Apr 11, 2014 9:08 pm
Ah I see , will it work tho ? It says it doesn't say what the connections are m or f but they look the same in the pic ?
Post Fri Apr 11, 2014 9:55 pm
It will be fine.
polsta
Post Sat Apr 12, 2014 6:25 pm
It best be :), il report back when it arrives
Got some JL Audio speakers 225/50 rms , through just the sqr88 it sounds great, much much better than the 4x vibe slick 50s set up I had in the is
Is it worth running the amp ? Will it give a better sound than the stereo even tho the 4x25 is the same? What sort if difference will it make ?
Post Sat Apr 12, 2014 7:04 pm
I've been running the same head unit and amp for two years now and to be honest, the amp is being replaced with a BQA160.
polsta
Post Sat Apr 19, 2014 10:25 pm
Lead arrived Barry, fits the cable I've got now making it male on each end is that correct ? Not removed the stereo yet
What other cables will I need and where's best place to put it ? I need to just hook it up 1st and make sure it works and sounds good or if maybe to get a 4x50 rms amp as the speakers are 50 and 60 rms
