Fitting 6.5" speakers is a turd of a job...
CiLK_WuRM
Tue Apr 11, 2006 3:02 pm
DanThe wrote:Well done Ian, thats exellent work 8)
Its nice to see someone with a setup like yours that DOESNT lisnten to Drum and Bass :lol:
ie. Dookie and Music For The Gilted Generation :rock:
If I owned Ian's car, all i'd do was drive around listening to Dillinja at vol 11 all day!
dippae30
Tue Apr 11, 2006 3:17 pm
genesis amps are top stuff
ian332isport
Tue Apr 11, 2006 7:37 pm
I'm in the process of building the new amp enclosure. It's a tight squeeze, but I think I can get it all in.
I've also got a bit of wiring ahead of me :eek:
Ian.
Tue Apr 11, 2006 10:09 pm
My alpina has 6.5 fitted front and rear, but somehow i don't think they have been fitted aswell as yours! But from what i can tell u is theres no rub on the glove box when opening and it still has the E30 bonnet release.
Tue Apr 11, 2006 11:21 pm
CiLK_WuRM wrote: vol 11
8O 8O
Only Spinal Tap play at Vol 11 8)
peter325i
Mon Jun 12, 2006 7:24 am
Hey Ian,
I am building a similar amp/sub enclosure and I plan to have my subs in the same spot. But, I'm a bit worried that the sound will be muffled with the armrest up.
How does the bass sound when the armrest is up? Is there a huge difference?
Thanks!
ian332isport
Mon Jun 12, 2006 5:50 pm
peter325i wrote:How does the bass sound when the armrest is up? Is there a huge difference?
Hi Pete,
It makes little or no difference having the arm rest up or down.
Cheers,
Ian.
peter325i
Mon Jun 12, 2006 6:58 pm
Thanks Ian. Good to know.
By the way, awsome job on the install. That is some quality work. Where do you find that grey carpet? It matches perfectly!
ian332isport
Mon Jun 12, 2006 9:43 pm
peter325i wrote:By the way, awsome job on the install. That is some quality work. Where do you find that grey carpet? It matches perfectly!
Thanks :D
That's actually my old install. You can follow the progress of my new one here:
http://www.e30zone.net/modules.php?name ... ic&t=34663
I actually got the carpet from Huet's car audio in Hove. It's not a perfect match, but it's close enough 8)
There's a label on the packaging that says 'M A Distributors'. A quick google found this http://www.ma-d.net/.
It's just called Grey trunk liner carpet NA31 (2 metres x 1.2 Metres).
Cheers,
Ian.
Dan318-is
Sun Jul 22, 2007 5:49 pm
Just dug this thread up, Ian your work is unreal mate.
Don't fancy making me one of those handles do you :lol:?
tomtomiS
Tue Jul 24, 2007 1:25 am
Dan318-is wrote:Just dug this thread up, Ian your work is unreal mate.
I second that, truly excellent effort there, its given me a $%£ load of inspiration.
