Fitting 19's ???
Player6 has 19's on his car, not sure if he needed any arches rolling.only prob with 19's is limited choice of wheel in 4 stud configuration.
send him a PM mate
send him a PM mate
19's go on prity easly the hard bit is getting the wheels to fit in 4x100
scot 328i with 260bhp
ive already seen the wheels i want, i just need to get some 20mm spacers as they sre 45 offset. Any ideas where to get some. cheers.player6 wrote:19's go on prity easly the hard bit is getting the wheels to fit in 4x100
what wheels are thay sre thay ace
you need to upgrade the brakes if u run 19's
think hard befor giong 4 them 19"s are big with et 45 u need 25mm spacers do u uses the car alot
player6 wrote:think hard befor giong 4 them 19"s are big with et 45 u need 25mm spacers do u uses the car alot
I dont use the car a lot as I live at work so dont need to use it much.
You mentioned before about the brakes do you know what will it cost to upgrade them
what e30 u planing to fit them to
thats going to slow it down so much what size u on now the boss wheels weigth some
where u from if i was u go 4 some 17's or at a push 18's on a 318 i have the power 4 the 19's on my car (250bhp)
thats ok m8 pm me if you want 2 no anythink
