M3 KIT
has anyboby done the m3 conversion using an aftermarket fiberglass kit? I would like to know which one is considered good and if in the long terms there are cracks where fiberglass meets the metal on the rear panel, thanks
1991 325 cabio t/c 3.2 evo, 6speed, e36m3 rack, adj bilstein,
http://s241.photobucket.com/albums/ff262/granitsas/
Dont waste your time. By the time you finish it would have cost you as much as a real M3, except it wont be and all Fibre Glass crack over time if you use the car regularly.
thank you, I just had the same opinion here in greece, pitty, Nikos
