Surely not!!!! how to plug and re-drill BBS's
Dezzy is thinking about this isn't he?
One could see the sense in this, perhaps, if they were 16", but for 15" BBS, why not just get the normal 4-stud ones?
leeparkes
What do these RS 244's look like? just done a quick search but cant find anything apart from this listRav335uk wrote:Yes RS 224'sImysE30 wrote:Doesn't look safe...
Think they are RS's
http://www.wheel-whores.com/forum/viewtopic.php?t=726
Oh and i cant realy see the problem doing this if done 'correctly', cant be any worse than a multistud bk rep,
BBS's are made from good quality alloy
I wouldnt do it though
- E30 Zone Meets/Events Team
- Contact:
I wouldn't fuk up a BBS wheel for that, i'd go out and buy the bloody right one, oh I did
BBS RS 224 looks like any other BBS RS wheel Lee.
All it tells you by that number is basically the offset, wheel bolt size and centrebore size.
- Contact:
Are you getting those then??ImysE30 wrote:Complicated or what![]()
Rav, the wheel you posted in the OP has the same fitment as the one's from RB (orginal holes)
I really want to but i need to spend my money elsewhere first, like suspensionRav335uk wrote:Are you getting those then??ImysE30 wrote:Complicated or what![]()
Thanks for the link
HairyScreech
technicaly yes, that is the right way of doing it. its far more common on older or yank stuff than over here on our new fangled bmws.
Bodge or not, it's certainly ingenious. I'd be interested to know more about the process of plugging alloys, out of interest. Anyone have any links?
psychochild187
they dont look central though
im looking at the distance from centre bore lip to hole edge
some look further away
E30SPDFRK
That is actually one of the most correct way's to do it. The plug's don't heat up and warp the metal like welding would. Also they filled in all the holes, even the ones that don't interfere with the new holes, so that the wheel will balence out better.
-Byron
