Engine capacity increase???
isTURBO
Post Tue Apr 08, 2008 2:17 am
Hi guys
Im contemplating doing up my 323i motor, so just a feeler for now as I may get a 325 motor as a replacement, however i was wondering if I were to do up the 323i engine what could I increase the engine capacity to if any in terms of a stroker setup?
Any help and advice would be greatly appreciated.
Imageselling more bunnies to pay for my conversion
fowler
Boost Junkie
Post Tue Apr 08, 2008 3:25 am
Rivvage.. you will need to take the 323 block you have now bore/hone to 325i piston size then get some Late (post88) pistons and a rare as rocking horse shit TD crank. to build yourself a low comp 327 turbo compatible engine. you could poss build a 2.8 turbo but my knowledge on this stroker build is next to nothing.
best of luck.
regards
ben
EX A-Tech Workshop bitch !!!
gone but not forgotten
isTURBO
Post Tue Apr 08, 2008 9:15 am
Cheers Ben
So a post 88 block with pistons etc and the 323 head as per the 2.7 build sticky should do a 2.7 low comp enginge but I would need the TD crank.
This would avoid the machine shop route then.
Anyone know if the 328 build is easier?
march109
Post Tue Apr 08, 2008 9:58 am
fowler wrote:Rivvage.. you will need to take the 323 block you have now bore/hone to 325i piston size then get some Late (post88) pistons and a rare as rocking horse shit TD crank. to build yourself a low comp 327 turbo compatible engine. you could poss build a 2.8 turbo but my knowledge on this stroker build is next to nothing.
best of luck.
regards
ben
For 2.8L start with a 2.5 or 2.0 M20, the 2.0LM20 needs to be bored out to 84mm (same bore as 2.5) chuck into it the non vanos M52B28 crank M20B20 rods and M20B25 pistons and you have 2.8L as templ8e30 has done.
http://www.e30zone.net/modules.php?name ... 78&start=0
Click Here
2.8L is easier than a proper 2.7L where you deck the block and use a vernier pulley, the basic 2.7 where you slap a 2.5 head on a ETA engine though couldn't be simpler or cheaper.
2.8's main expence will be the crank they can be had for as little as £100 but often sell for as much as £250.
The rest of the parts are pretty cheap if you allready have a 2.5L M20 that is, since the b20 rods are often peanuts.
I'm building a 2.9L with custom pistons, rods and a few other special parts, for the MLS gasket, pistons, rods and crank I have spent just a shade under £1000, thats before actually starting the build.
isTURBO
Post Tue Apr 08, 2008 3:45 pm
Thanks guys
Ben the TD crank comes off which cars engine?
March 109 what would I require for a low comp 2.8 build as I'm going the FI route.
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Tue Apr 08, 2008 4:35 pm
m21 diesel motor, go on ebay.de and type in m21 bmw, there are usually on there quite alot
fowler
Boost Junkie
Post Tue Apr 08, 2008 5:45 pm
2.8 is no good for FI as it has too much recipricating weight. the rods would possibly bend
