my m50 conversion
les3002
Fri Apr 04, 2008 11:06 pm
here is the donor car picked up off ebay for £300 with a snapped cambelt totally rust free,
and the engine which i got for free out of my mates 92 e34 525i
old wheeze pot m40
empty bay
going in :)
in :)
modifyed m52 manifolds to fit around the e36 rack
where im upto at the minute, need to sort the prop and downpipes next.
1989 BMW 318i (2.5 24v conversion in progress)
1993 Vauxhall Cavalier 4x4 Turbo
eko
Old timer
Fri Apr 04, 2008 11:15 pm
Nice progress there mate and engine bay looks nice and neat too.
What servo did you opt for?
Ive used Golf ones on my last 2 conversions but after driving Benjys M50 with Clio servo ill definately be using one of those on my next conversion.
les3002
Sat Apr 05, 2008 12:03 am
it was a mk1 golf gti servo mate, does the clio one feel alot better then?
got the wiring done the other day just need to sort the exhaust before i can see if it starts :)
les3002
Sat Apr 05, 2008 12:04 am
one question
there is a big pipe coming up around the air filter (looks like a breather that connected to the old airbox) what have you done with that?
eko
Old timer
Sat Apr 05, 2008 12:42 am
les3002 wrote:one question
You mean with the sensor attached which bolts on?If so I just tucked it out the way under my M30 airbox.
As for the Clio servo.I drove Benjys car this week and the brakes are perfect.Stopping power and pedal feel/height is perfect.
As for the Golf one:pedal always feels `too hard`.Dont get me wrong they worked well enough just took some getting used to the feel.
benjy
Sat Apr 05, 2008 12:48 am
In the fifth picture it looks like your got the aircon bracket still fitted.....that needs to come off1 :D TIP, chase the engine mount threads with a tap! make life easier when you dont crack the block.....It has been known :?
Clio servo's rock :thumb:
Cheers, ben
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Andy325i
Sat Apr 05, 2008 1:01 am
Good work :) Nice to see more 24 valve rightness winkeye
Andy
les3002
Sat Apr 05, 2008 11:15 am
no mate not that sensor, i think thats a valve to heat the throttle when its cold isnt it? was just going to remove this, the pipe i mean is about 30mm diameter.
yeah the aircon bracket is still on, didnt fancy removing the front pulley so left it on as its not doing any harm i dont think, as you can see aswell when fitting it i did forget to move one of the e36 mounts to the rear mount holes and did run a tap down the holes after id snapped a bolt in one and had to drill it out, doh!
ed325i
Sat Apr 05, 2008 11:26 am
I have moved the e30 servo over about 1 1/2", I will see if it clears when I put the engine in.
ha22
Sat Apr 05, 2008 10:41 pm
nice job ed, what gearbox, fly wheel and clutch are you using. i'm gonna start my conversion when the weather take s a turn for the better.
ed325i
Sun Apr 06, 2008 11:00 am
I have got 2 boxes I can use the m50 and the m20 box.
If I use the m50 box I have got to get a prop and change the diff
so I am going to use the m20 box with the m20 flywheel etc.
If I was to use the m50 box I would still use the m20 flywheel as its lighter.
Andy325i
Sun Apr 06, 2008 12:32 pm
Ed, won't the M20 gearshift be in the wrong place as the M20/M50's sit on different angles?
ed325i
Sun Apr 06, 2008 3:33 pm
Yes the m20 box will sit at a different angle but the gear linkage can be bent to fit.
dave525
Mon Apr 07, 2008 8:08 pm
i might be wrong but i thought you can use the m40 box.andyboy said something about this i,m sure.
eko
Old timer
Mon Apr 07, 2008 8:11 pm
ed325i wrote:Yes the m20 box will sit at a different angle but the gear linkage can be bent to fit.
Ed,just why not just spacer(or get a thicker) engine mount rubber to rotate the engine and box?
Mon Apr 07, 2008 8:15 pm
You dont want to be rotating the engine, sump will be on the p1ss
eko
Old timer
Mon Apr 07, 2008 8:18 pm
DanThe wrote:You dont want to be rotating the engine, sump will be on the p1ss
Good point :o:
les3002
Sun May 25, 2008 2:38 pm
small update:
got bored at work so decided to try and mod the original e30 gearlinkage as i wasnt having much look at the local scrappy, worked pretty well sits the gearstick perfect.
also fitted the 328i prop i got with an e30 centre bearing and fitted it up.
all thats left to do now really then is:
fab the exhaust downpipes
sort out wiring to the electric fan
have pas feed pipe to e36 rack made up
then its just fluids etc, it did start up the other week so seems like the wiring is all good :)
Demlotcrew
Sun May 25, 2008 4:28 pm
This will only cause the prop to sit on the total piss!
A
ed325i
Sun May 25, 2008 5:53 pm
I have just been out to measure my prop to see if its sitting in the middle of the tunnel and it does.
Ant
Retired Team Member
Retired Team Member
Sun May 25, 2008 5:59 pm
Have to agree with Ed.
spacing one mount to mate correctly once the box is rotated the X degrees it needs leaves the prop dead centre in the car Andrew.
The M50 g/box support is NOT used here, the stock M20 one is employed
siddiqi1
BFG Zone Contributor
Sun May 25, 2008 7:43 pm
that engine was never going in there.
i was looing at the third picture when i saw the engine being hoisted in and was like :eek: never gana get that in; i put my bottom dol...... 8O shit it went in!!!!!
looks like it was designed to be in there buddy; so well done and so suprisingly clean; doesnt look like its been bodged or anything!
excellent work buddy!
with regards to wiring; do you have to rip out all the E30 stuff and wire in the new engine loom completely?
Sun May 25, 2008 10:44 pm
It is surprising how they slot in at the right angle, mine came out today past the air con condenser, with the extra pulley on the front too! :D
Good work on the gear linkages, I suppose thats one way to add weight to the shifting action :D
OBs
Sun May 25, 2008 10:51 pm
Dan did that pump ever turn up??
Sun May 25, 2008 10:54 pm
Yeah it did Andy cheers, did it get run over or something?
Loving the avatar :D
OBs
Sun May 25, 2008 10:55 pm
Good job les3002 by the way :o:
OBs
OBs
Sun May 25, 2008 10:58 pm
DanThe wrote:Yeah it did Andy cheers, did it get run over or something?
No :eek: ??
Was it flat :?
siddiqi1
Sun May 25, 2008 10:59 pm
never knew a hoist could lift thaaaattt high!!!for such an angle.....good i supose to know its possible
Sun May 25, 2008 11:10 pm
No :eek: ??
Was it flat :?
Its bent down the support for the pump unit, should be able to straighten it out though, I put it on the forklift for 'safe keeping' and the level sender unit fell off as I was reversing :roll:
That bit did get run over :)
Sorry for the thread rape fella's
les3002
Mon May 26, 2008 9:54 am
cheers for the comments guys, i found just lifting it by the front lifting hook so its hanging vertically and the just pushing the box to the rear on a trolley jack was the easiest way of getting it in.
