gearbox/flywheel
ed325i
Post Tue Apr 01, 2008 6:12 pm
When using the m20 325 gearbox on the m50 engine what flywheel do you use ?
Ed
Ant
Retired Team Member
Retired Team Member
Post Tue Apr 01, 2008 6:47 pm
M20 fly, spigot and cutch assy Ed
Usefully lighter than the OE M50 unit too
All bolts up, no issues, you'll have 4 bolts in the lower bellhousing to redrill if you want but TBH, its the big-uns that do the job and they are spot on.
use M20 selsctor assy too, you'll need to mod the floor slightly where the top of the g/box is close to it, ther's a rebate for it if you look, replicate that in its new location, and alls well.
for the g/box mounts, use twio cradles, cut one up and use the parts to bridge the second to correct for the clocking.
ed325i
Post Tue Apr 01, 2008 7:31 pm
Thanks Ant :thumb:
ed325i
Post Sat Apr 05, 2008 3:29 pm
What is the best way to mod it so it fits ?
ed325i
Post Wed Apr 09, 2008 12:51 pm
I have just fitted my m20 flywheel to the m50 engine and the flywheel rubs on the back of the sump :?:
march109
Post Wed Apr 09, 2008 12:58 pm
I read somewhere on the M50 conversion using the M20 flywheel it needs to be machined down by about 3-4mm, ask Ant though he will be the man in the know on how and where to machine it down if at all.
ed325i
Post Wed Apr 09, 2008 7:48 pm
I have modded the sump.
There are to long sump bolts right at the back which the flywheel hits, so I took the bolts out and ground off the part on the sump where the long bolt go through and fitted shorter bolts and now it all fitted ok.
Post Wed Apr 09, 2008 7:56 pm
Ed, are you using an early or late M20 flywheel? The late fly I first bolted up clamped down onto the bolts that hold the rear crank seal ally piece
ed325i
Post Wed Apr 09, 2008 9:37 pm
I am using an early one
