My brother has an M30 engine from a M535i, is it worth swapping my M20 engine out of my 325 i track day car
my M20 currently has throttle bodies and a 6 branch and gives 169hp at the wheels
is the M30 much heavier? and will it be an easy swap
my only reason for thinking of it, is that the M30 already has 210 hp and loads more torque whereas to get 210 plus and good torque from my m20 is going to require a ETA engine block I think
Any ideas?
Swap M20 for an M30?
FormerMember
I wouldn't swap it to a track day car, M30 is ~50kg heavier than M20 and that's a lot in a track car...
Swap itself is easy, you just need E34 oilpan and oilpump, motor mounts (for example from www.300mm.de) and E28 535 radiator. And depending on gearbox you need driveshaft to be shortened.
You can find lots of info on www.e30.de / "335"
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
ed325i
Yes when it was new, most will need a re build.the M30 already has 210 hp
beefy
if you have an engine from a 5 series it will go straight in no need for the oil pan change. In position 3 the 5 series rad will fit.
And yeah shortened prop will be needed.
I can supply the mounts for £100
E30 M30 Mounts £100 pm me for info.
Paynts
Well after some enthusiastic driving at bedford with the oil light coming on and off round the bends something let go in the bottom of the engine!!!!
So I think it might be the 2.7 rebuild if I can find one!!
charlE30
The earlier engines (E28) do require the E34 sump and oil pump to clear the front subframe/steering rack or it'll sit to high.beefy wrote:if you have an engine from a 5 series it will go straight in no need for the oil pan change. In position 3 the 5 series rad will fit.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
