M30 intake manifold
gall
Mon Jan 14, 2008 12:24 am
i'm in the planning stage of turbo'in my m30 3.5 at was wondering if there's an exact science in making an ally intake manifold like the ones used on big power supra's/skylines???
pic below of what i mean,
http://us.st11.yimg.com/us.st.yimg.com/ ... 984_866457
i know that it's smaller at the back cause of fuel/air problems at the rear cylinder.
cheers
Andy.
Templ8e30
Mon Jan 14, 2008 9:11 am
The M20 manifold in your link is ok but where are they going to fit the throttle bodies ?
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Gunni
Mon Jan 14, 2008 1:52 pm
How much power are you aiming for?
Unless it´s really really serious, the stock manifold flows very well.
Gunni
@ 2012 VEMS group buy !!
Turbo-Brown
Boost Junkie
Mon Jan 14, 2008 1:54 pm
Just one big throttle goes on the end. Fine for use with a turbo and a very low overlap cam but should imagine it'd run like a sack o' crap with a bit of overlap on there!
ric325i
Mon Jan 14, 2008 2:00 pm
andy put a picture of the turbo up :D
people will see the game plan - but it may distract from the issue in hand???
doing a 'unna' special there with the mani, just block it in steal, they say the flow is not as important as a N/a engine.
are you going to do some CAD drawings?
Turbo-Brown
Boost Junkie
Mon Jan 14, 2008 2:03 pm
Flow isn't perhaps as important, but the better all of your system flows, the more power/psi you should see.
blitz877
AKA ajm-e30
Mon Jan 14, 2008 2:15 pm
can these be used on a non-turbo car?
Turbo-Brown
Boost Junkie
Mon Jan 14, 2008 2:17 pm
No reason why not, except you'd have a nightmare if you went down any N/A tuning routes (mainly the cam)
blitz877
AKA ajm-e30
Mon Jan 14, 2008 2:19 pm
Turbo-Brown wrote:No reason why not, except you'd have a nightmare if you went down any N/A tuning routes (mainly the cam)
in what respect mate? would there be any kind of bhp gain running on a basically standard engine?
ric325i
Mon Jan 14, 2008 2:40 pm
imo i would say no. you want a tubular mani for a N/A engine (even a turbo engine it would be better) but flow is essential for a mani and the standard bmw is good but a tubular mani is going to give you more power.
ed325i
Mon Jan 14, 2008 4:01 pm
gall
Mon Jan 14, 2008 9:01 pm
cheers for link.
here is alink to the turbo that i'm planning on use as it was free.
andy.
Turbo-Brown
Boost Junkie
Mon Jan 14, 2008 11:26 pm
I'd say that the shorter runners would likely as not move the power band up out of the range of standard components (not necessarily a hard and fast rule though) and that the charge robbing would give you a cack idle and low speed drivability if you had lots of overlap.
My feeling is that the shorter runners and bigger plenum would make the problem of high overlap cams worse than perhaps the standard long runner intake but I don't have anything to back that up.
Andy335Touring
Tue Jan 15, 2008 6:57 pm
You could always use the standard manifold and fit a bigger TB to the other side like my twin 60mm TB, it will be handy for the intercooler piping having the TB on that side, it's also away from the hot side of the engine so less heat pick up.
It's still not a five minuet kind of job but might give you another alternative to consider ?
gall
Thu Jan 17, 2008 5:38 pm
yeah andy i do like the look of your new manifold and it would save me making a complete new one from ally, any chance you can remember what engine the throttle body came off?
does it make any difference now with the new one on?
gonna go and speak to me mate that builds drag racing cars for fun (1400bhp supra, 1000bhp skyline, 1200bhp mk2 cortina) all are road legal and very very fast!!!!!!!!!!
cheers
andy
Andy335Touring
Thu Jan 17, 2008 7:03 pm
I got it off US ebay for about £40-50 inc shipping and taxes, i think it was off a Ford V8 Mustang of some sort but there's plenty of them on Ebay.
I've not got the engine mapped yet to suit the TB but it does seem more perky, it will probobly benifit(sp?) you better as you will be making more power and need to flow more air which ever TB you end up using.
The one slightly PITA thing with this TB is the TPS spindle isn't the usual "D" shape it's a flat blade type thing(blue part in the picy) you will either have to find a TPS that will fit and be able to work with the ECU you use or make an adapter.
I was very gratefull to have some one from here to make me one up, see below.
I almost forgot, you will also have to re-locate the PAS res' lower which easily done with an E36 res' bracket or mod the E30 bracket to suit.
Turbo-Brown
Boost Junkie
Thu Jan 17, 2008 10:25 pm
:lol: that looks familiar Andy :D
Andy335Touring
Thu Jan 17, 2008 10:43 pm
eye, thank ye kindly good sir ! :)
gall
Wed Jan 30, 2008 12:28 am
this is the sort throttle body i was thinking of using with the ally plenum chamber like the ones that 666 make.
throttle body,
http://cgi.ebay.co.uk/80MM-THROTTLE-BOD ... dZViewItem
plenum chamber,
do you think that throttle body would work or will i have to mod it??
andy.
Andy335Touring
Wed Jan 30, 2008 5:16 pm
Have a look in the for sale section as Toby is breaking his turbo M30 with the M5 throttle body set up.
jaffro
Wed Jan 30, 2008 5:20 pm
andy have you got any more pics of your inlet mani so i can see where the breathers a pipes go? :P
Andy335Touring
Wed Jan 30, 2008 5:35 pm
which ones ? crank case breather ?
The crank case breather pipe on a stock M30 goes from the rocker cover to the rubber bellows inbetween the AFM and the TB.
On mine the breather goes under the manifold and connects up to the underside of the black G/F elbow
jaffro
Wed Jan 30, 2008 6:41 pm
i was going to try this useing standard throttle body just so the airbox was on the same side as the m20 box and away from the heat. :P
Andy335Touring
Wed Jan 30, 2008 6:51 pm
Toby did that before the M5 TB's
jaffro
Wed Jan 30, 2008 6:55 pm
wonder if he got any pics then winkeye . by the way yours looks mint
gall
Thu Jan 31, 2008 12:38 am
just sent Toby a pm about the throttle bodies, any idea what they'll be worth?
cheers
Andy.
Andy335Touring
Thu Jan 31, 2008 5:31 pm
I'm not sure because there's a lot of work gone into them to get them fitted.
Just bog standard M5 TB's/plenum arn't cheap.
