DIY Ebay Intercooler
pilt
Post Sun Jan 13, 2008 4:33 pm
Hi
Been looking at intercoolers on Ebay and found this one
http://cgi.ebay.co.uk/FMIC-FFRONT-MOUNT ... dZViewItem
But decided I could probably make it cheaper for myself, since I had all the materials laying about in the house....
Should be good for around 1 psi, maybe 2 especially if I reinforce it with some PVA :)
Only probelm is the bumper restricts the airflow slighty....
but this should protect it from the rain at least, stop it disintigrating :o
What you reckon?
Anyone else used these cheapo ebay intercoolers?
grayzo
Post Sun Jan 13, 2008 6:45 pm
can i have one
BadDave
Post Sun Jan 13, 2008 8:21 pm
Sorry dude
Haven't used one of them but i could suggest a cheaper alernative
It would mean you having to relocate the oil cooler or remove it altogether
From an old Volvo and fills the frontal area nicely,whilst still leaving room for a leccy fan between it and the rad
Just a thought
chrisr29
Post Sun Jan 13, 2008 8:31 pm
That's bollox mate!
You need to use corrugated card.
chrisr29
Post Sun Jan 13, 2008 8:32 pm
That's bollox mate!
pilt
Post Sun Jan 13, 2008 10:49 pm
BadDave wrote:Sorry dude
Just a thought
Do you know what volvo it is from?
I guess you have to move the radiator back to fit that one?
BadDave
Post Sun Jan 13, 2008 10:56 pm
pilt wrote: Image
I guess you have to move the radiator back to fit that one?[/quote]
It's either from a 740/760 or the 940/960
Can't actually remember which one :hammer: :x
Some of them have the I/O pipes half ay up the cooler
I THINK ist from the 940 but can't be sure
I haven't actually fitted it yet,however,all the measurements suggest the rad does not need moved at all and there should be sufficient room to fit a spal/kenlowe/wipac fan between the rad and cooler
Failing that, a fan from a Chavalier 1.7TD is quite thin and should fit
HTH
Dave
pilt
Post Sun Jan 13, 2008 11:14 pm
So your fitting one just like that or the one with the outlets halfway up?
BadDave
Post Sun Jan 13, 2008 11:20 pm
pilt wrote:So your fitting one just like that or the one with the outlets halfway up?
I'll be fitting this one,once i've got all my turbo goodies sorted out and dummy fitted on a tourer i'm breaking.
Just need to dummy fit/fab the rest of the parts and then swap them to the 2.5 tourer after i've got my coilovers,ITB's,plenum chamber,and standalone ECU fitted
pilt
Post Sun Jan 13, 2008 11:28 pm
Looks good, after all it is massive!
What size piping are you running, does that intercooler have 2.5inch connections?
So if you dont move the rad where are the outlets going to go? I assume you intend to put it upside down and have the pipes coming from underneath? Does it interfere with the brake ducts or the fog lamps at all?
Sorry for all the dumb questions, just trying to imagine how it all fits!
Pilt
BadDave
Post Sun Jan 13, 2008 11:40 pm
pilt wrote:Looks good, after all it is massive!
Pilt
It's 590mm wide at the top
740mm wide at the bottom(where th I/O are)
It's approx 445mm high and 57mm wide with 65ish mm I/O and WILL fill the entire centre frontal area on the E30
The I/O are where the oil cooler would normally be on a 325i andf the intercooler extends to the bottom of the front valance,hence my referance to "taking up the entire central frontal area"
It is going to be mounted upside down and does not,AFAIK interere with the brake ducts and does not extend anywhere near the fog lamps unless you route your pipework into that area
HTH
DAve
pilt
Post Sun Jan 13, 2008 11:43 pm
Cheers for all your help mate, will have to keep my eye out for one of those, sounds perfect!
Looks like its off the 740
http://www.student.kun.nl/p.oonincx/Intercooler.html
Near the bottom
Pilt
BadDave
Post Sun Jan 13, 2008 11:47 pm
If you Email or phone ANT from here on the zone(He's one of the Mods on here),he'll be able to tellyou which model of Volvo it comes from, as IIRC he ha sone fitted to his red 325i fitted with a T3 and is very helfull Re all things engine related,whether it be N/A, Turbo,supercharged,Megasquirt and aftermarket ECU's or even nitrous
HTH
Dave
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Mon Jan 14, 2008 12:07 am
i have one of those intercoolers for sale if you want it? shameless plug.......
