pistons for 2.8
ed325i
Post Thu Jan 03, 2008 8:57 pm
Building a m20 2.8 and I have got early high comp pistons, will be using a cat cam, but I am worried the comp ratio be to high ?
Thanks Ed
Geoff
Post Thu Jan 03, 2008 10:05 pm
There is an article in this months Total BMW mag in the questions and answers section about building a 2.7/2.8 and what is needed. HTH
maggspower
Turbo Farmer Tractor Driver
Post Thu Jan 03, 2008 11:40 pm
the compression ratio is quite high when using the pre facelift pistons at around 10.8-1, but with the overlap of the cam, it should come down a bit.
you could run it on super unleaded. :) your not building it to be economical are you winkeye
