problem with megasquirt HELP
hass
Post Thu Dec 20, 2007 9:59 pm
Hi guys got my turbo 2.5 running on m/s
and i have a fooking nightmare in the morning starting the car
been down to ants he was the one who fitted it up and im trying to do sum tweeking.(very helpful guy)
but i was just wondering if any one else has had this sort of problem.
basicly what happens.....
i jump into the car in the morning and flick the ignition on.
wait 32 seconds for the wideband to warm up.
start it
it will run on 3/4 cyinders for 3 seconds then die
crank it
crank it
crank it
crank it
then fire up run oln 3/4 sec then die
crank it
play with the throttle while cranking
cranking
cranking
then catches and it idles really rough, i go to rev and cuts out
i start it again and it catches but i have to hold the revs .
if i let go it cuts out, so i have to hold it reved up for about 3/4 minutes
then fine.
now something else happens but dont know if its linked
but once engine is warmed up and its all kool
if i turn it off for lets say a minute and i go to start it it runs really rough and i have to rev it a bit to clear then fine up untill i turn it off.
i know its a bit hard to explain.
im in the process of tweeking it with ant
but i was just wondering if any1 had this problem or similar.
every bit helps.
thank you hass
and merry christmas to all the zoners,
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Dec 20, 2007 11:56 pm
ant is the man to ask mate :cool:
hass
Post Fri Dec 21, 2007 6:17 pm
me and ant are already in process of tweeking the m/s :D
but was just wondering if any 1 else came across this problem
thanks
