turbo/superchargeing, what about brake servo vacuum etc. . .
sumo_e36
Post Thu Dec 20, 2007 6:58 pm
As above. when you turbo or supercharcharge a N.A engine what do you do about the vacuum fed ancilliaries (brake servo etc...) are there electric ones on the market
Post Thu Dec 20, 2007 7:09 pm
There's still the same manifold vacuum, when you close the throttle, which is the usual state when you use the brakes!
boombang
Post Thu Dec 20, 2007 7:11 pm
they use a one way or "check" valve on the vaccuum hose :)
sumo_e36
is that the definitive answer then, you leave it as it is
boombang
Post Thu Dec 20, 2007 7:16 pm
Depends if it has a one way valve in already or not - if you do then yes.
Alternative is to either switch to pedal box with master cylinder appropriate for non-servo assisted braking or as you said running another vaccuum source (which I can't say I've seen unless you were to adapt a diesel type, some cars it is on the alternator, others driven off an engine belt)
Post Thu Dec 20, 2007 7:42 pm
boombang wrote:Depends if it has a one way valve in already or not - if you do then yes.
AFAIK, all vacuum servos have a one way air valve!
Turbo-Brown
Boost Junkie
Post Fri Dec 21, 2007 3:11 am
Pedal box or not, there will still be vacuum in the manifold when the throttle's closed.
Seems that pretty much every car has a one way vale so just leave it as it is.
