any input would be great
which transplant?
iwannae30
hi guys
eventually i want to combine lots of power with good handling in my e30. ive been researching engine transplants but am a bit overwhelmed by the amount of options there is. what do you think the best option is?
blitz877
- AKA ajm-e30
whats the best you can afford??
fuzzy
ford cosworth is the best imo but you will need deep pockets.
maxfield
Got to agree, a 4 pot up front is the way to go.fuzzy wrote:ford cosworth is the best imo but you will need deep pockets.
So that leaves an M10 or S14.
You can extract good power from both, either N/A or F/I.
brian325i
id say s50,280ish bhp out of the box with possible fi in future,6pot sound,and relatively cheap thesedays
S50 is alive
iwannae30
yeah iv seen guys get 400+hp from fully blown m10s
although its only an 8 valve
can you get 16 valve heads for m10s?
how much do you reckon upgrading an m10 until its beter than an s14 will be? dont fancy looking for an m3 to use it as a donor to be honest
thanks
thanks
maxfield
An M10 will never be better than an S14, due to it having 8valves.
The blocks are pretty much the same.
Depends how much you want to spend, sky's the limit with an M10.
- E30 Zone Meets/Events Team
M30 the thing
FormerMember
1600cc M10 with 3,8bar boost => 996hp
Anyways, regarding the swap, it all depends on your budget. S50 is easiest and possibly the cheapest way to get 300hp reliably with very small fuel consumption. But there're tons of choices, just pick the one which suits your budget, skills and needs best.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
N00b
Sorry to thread hijack, but is a reliable and tractable 250 possible using something from the M50/52 range possible on a budget.
By budget, I mean once you've bought the actual engine ie minimal mods to get into the mid 200's BHP wise.
Look at Danthe's motor, 242bhp iirc.
