Anyone got a getrag 260 325i box lying about?
alistairolsen
Post Sat Dec 01, 2007 12:40 pm
need some measurements if you dont mind!
I need the length of the input shaft, froma line taken accross the mating face with the block, both to the ends of the splines and the end of the spigot.
I need the diameter of the spigot where it goes into the spigot bearing in the crank
I need the diameter of the 325 friction plate
Many thanks
Post Sat Dec 01, 2007 2:16 pm
6mm in from the face, 41mm in from the face and spigot diameter is 12mm.
Haven't got a clutch plate handy, but it's probably in the ETK.
IIRC, there was a change of spigot diameter at some time during the E30s life.
alistairolsen
Post Sat Dec 01, 2007 6:07 pm
absolute legend, so thats 6mm in to the start of the splines? then 35mm of splines, then plain?
How long is the spigot section?
clutch plate is apparently 228mm, sound about right?
Many thanks for that
alistairolsen
Post Sat Jan 03, 2009 3:09 pm
bump
BadDave
Post Sat Jan 03, 2009 4:56 pm
Clutch plate should be 228mm IIRC
MarkF
Post Sat Jan 03, 2009 5:10 pm
BadDave wrote:Clutch plate should be 228mm IIRC
Yes i believe that to be correct and also as far as im aware the 320 and 325 share the same clutch???
alistairolsen
Post Sat Jan 03, 2009 5:12 pm
do any bmw models have a 240mm friction plate with the same spline pattern?
