Is your engine pretty standard ?
As TB's won't make a massive power increase on a stock engine, they will look and sound cool, make the throttle response better.
As a bare minimum to make this worth while i'd say you need to lose the AFM and switch to a piggy back/stand alone ECU.
TB's, cam and lose the AFM and switch to a piggy back/stand alone ECU will get you some better results because the engine can flow more air with a cam.
Sorry if this sounds a little negative but i wouldn't want you to go through with all this work and expense and being disapointed with the gains.
Just to give you an idea of the difference in various set ups i worked out the surface area of the TB butterflies i was going to fit to mine(E28 M5 TB's) and the twin 60mm TB i ended up using.
This is a copy and paste of an old post i wrote.
_________________________________________
I was going to fit some M5 TB's to my M30 but i think they are over sized for my engine, over complicated and more likely to leak air if i ever turbo charge my car.
A mod i have seen on an M30 turbo relocates the standard TB to the other side of the inlet manifold so running the intake/charge pipe work is easier, this also has the benefit in N/A guise of placing the air filter and intake pipes on the cold side of the engine away from the exhaust manifold.
The flat side of the inlet manifold is roughly 95mm x 200mm so i can fit a fairly big TB to it once it has been skimmed flat. The stock TB is 64-65mm. I had a look on the US ebay site for a bigger TB(UK ebay was useless) and there was a wacking big 90mm TB but it probobly would have been to wide.
But this one should do the trick mounted virtically(sp?) with the throttle mech' on top and the TPS on the bottom. Not sure yet weather i'm going to bolt it on or have it welded on ?
Â
Each TB is 60mm, to compare the sizes of the TB's i have worked out the total surface area in mm2 of the following TB set ups.
M30 = 3318
2 x 60mm = 5654
M5 TB's = 9542 (or nearly three times bigger than the stock M30 TB !)
Unfortunately people on the stock AFM/ECU set up won't be able to do this mod unless you swap over to either a big MAF and Unichip or a stand alone ECU like megasquirt/Emerald/ETC.
This mod will hope fully compliment my existing mods(head/cam/Emerald/larger injectors) and if i ever turbo the old M30 it will be handy to have the TB located on that side of the manifold.
Sorry for rambling on but i thought it might interest some M30 modders, what do you think ?________________________________________________________
Just to add the when i worked out the surface area i didn't include the throttle spindle in the sums.
