Ignition system choices?
lentec
Boost Junkie
Thu May 12, 2005 8:34 pm
have spent the last few months building an eaton powered 2.7eta
phase2 http://lentec-e30.tripod.com
anyone have any ideas on stand alone ignition systems as i no longer have space for a dizzy! so im looking for somethin that dosnt need to use the oem crank trigger on the flywheel! preferably multi coil setup!
thanks all.
Turbo-Brown
Boost Junkie
Thu May 12, 2005 8:45 pm
Wahey!
Like that :) Which supercharger did you use?
If it were me, I'd junk the original engine management altogether and get a mappable ECU that can control the fuel and sparks relative to engine speed, load and boost.
Whereabouts are you from?
Cheers!
Ant
Retired Team Member
Retired Team Member
Thu May 12, 2005 8:51 pm
Welcome to the zone M8, nice project engine !!
I like the Alternator swop idea, had you considered using the A/C compressor bracket for the alt ?, would have done the job sweet dude and kept the alt mounted very low in the bay.
bit late now though but its worth a mention for others that will , no doubt follow in your footsteps :wink:
keep us posted dude :thumb:
lentec
Boost Junkie
Thu May 12, 2005 9:16 pm
the s/c is from a 3.5l slk merc! its an m90
am glad you like
will upload new pics later the whole designs a changin AGAIN!!
alex im in essex
has anyone had any sucess with one of those msd stand alone ignitions
ie: Programmable Digital-7 would hate to blow that kind of money on somthing i cant get running!
my old setup ran quite well. it could have been a lot better!
now i got the option of using the front cap thing but im not sure.
did want to go for some kind of "coil on plug" system.
Ant
Retired Team Member
Retired Team Member
Thu May 12, 2005 9:24 pm
thought about Bowling and grippos mega squirt at all ?, upgrade that to MSnS ( and spark) using a GM or ford EDIS module for a cheap muticoil setup, its a good and well regarded setup.
have you checked out www.e30tech.com, its a US site and there is a lot of info to be had with a quick browse of the turbocharging forum.
My MS should arrive next week, I'll be running again Wohoooooo!
Turbo-Brown
Boost Junkie
Thu May 12, 2005 9:54 pm
The only advantage I can see to coil on plug is the charge times for the coils being longer thus giving more consistent sparking. Can't really see a 6cyl DIS coil pack being that much worse.
In terms of buying an ignition only system (other than the options ant mentioned) I'm not sure how many people offer them.
Think that DTA and OMEX do a system that supports coil on plug, but they do fuel too.
Not really sure how you'd hold the coils on either as certainly on my M3 engine they're stuck down the plug tubes and then bolted down for good measure.
TVRTASMIN
Fri May 20, 2005 7:27 pm
The Ford EDIS system has a seperate coil unit with four or six outlets depending on which engine it is for.
I've got a 24V Cosworth engine to go in my Tasmin racer using the 6 post coil pack and seperate ignition leads.
My bog standard 24V Alfa uses seperate coils with plug boots etc attached and clamped to the rocker box.
Ant. Any news yet on the Megasplurge? :P
Ant
Retired Team Member
Retired Team Member
Fri May 20, 2005 8:23 pm
Yes mate, all bad :lol:
Its yet to be shipped, Jim ran into some issues in testing and had to wait for a replacement TPS to arrive
Monday/Tuesday next wekk hopefully , I'm certainly keeping them crossed, B/H weekend innit.... perfect modding time :twisted:
lentec
Boost Junkie
Sat May 21, 2005 11:02 am
going on a trip to the breakers today will see what ican find.
thanks all will keep you posted
lennie
lentec
Boost Junkie
Mon May 23, 2005 7:13 am
looks like the later 5 series fitted with the m20 had a 62 -2 front pulley and sensor!
bolt on replacement! and after speaking to the guy from emeraldm3d this will be enough to trigger a wasted spark system.
the headach continues!!
