So what the guy did, was remove the dump valve and dis connect the actuator, resulting in the car running at 3 psi max at top end, in order to reduce the oil problem. The car seems to be running alright driving normaly.
After starting the turbo conversion, i discovered that the engine was the high compression 'E' version, so i wasnt expecting it to have huge power, but the rolling road result with the above settings came out as 173BHP @5300
I know that the boost is very low, but i thought it would at least be a bit higher than they are suppose to be standard??
Im getting the engine tested for rings this weekend, but for now im open to suggestions as to what it could be?
thanks, jonathan
