M20B28
abelai
Is there anybody(traders) selling the M52B28 crankshaft with the front space already machined to size to drop straight into an M20B25 with M20B20 rods obviously? If yes how much?
If I can't fix it I'll f**k it up so bad nobody can!!
StuBeeDoo
abelai
Sorry I should have said 'the front "spacer" already machined' normally made from the M52 crank pully hub. This conversion to a 2.8 seems to be the cheapest good performance mod available for the M20B25.
Mattoz1
Ireland engineering does a stroker kit, including the crank, spacer, custom pistons for use with b25 con-rods(with custom CR) for about US$1800 + postage
