Spare bits left over... (turbo related)
e30_Turbo
Boost Junkie
Post Mon May 09, 2005 10:54 am
Hello all,
Due to my recent MS purchase I now have a pair of M30 AFM's for sale.
The first is a std M30 AFM, no mods, completly std, missing top cover, should work fine, this ones open to offers. Has the same plug as std M20 AFM. Been told that with a adj fuel pres reg these can be used.
The second is a Hybrid with a M20 2.5 board fitted. I'm looking at as much Ԛ£Ã”šÃ‚£ as poss for this as it owes me Ԛ£50 and it has never been outta me shed since I got it.
Now these were going to be used on mine in conjuction with a adj fuel press reg but not needed now....so if anyone is in need let me know.
Cheers,
Mark.
SHAKEELE30
Boost Junkie
Post Tue May 17, 2005 2:12 pm
just out of curiousity, what are they be used for. If you dont mind me asking u a stupid ?. also how much you want for them..cheers
e30_Turbo
Boost Junkie
Post Tue May 17, 2005 3:52 pm
SHAKEELE30 wrote:just out of curiousity, what are they be used for. If you dont mind me asking u a stupid ?. also how much you want for them..cheers
No worries, these are the larger M30 engine (3.5ltr) Air Flow meters. They have a much larger internal size so will flow more air through them, which is what you need for FI. But if you're thinking about a new ECU that uses MAP sensors then you won't need one of these.
One is a standard unit, straight off the car and the other is a M30 AFM with a M20 AFM chip in it, so basically it still thinks it's a M20 AFM, but flows more air.
The M30 AFM with the M20 board cost me Ԛ£50, is all there, will fit onto the std M20 TB boot with some heat to help.
The std M30 AFM, well I suppose roughly the same price.....
I've bought a new ECU so no need for these anymore!!
HTH, Mark.
