lamb. sensor power source?
jondrift
where is the best place to wire the power for a lamdor sensor? I have currently taken it from the power to the ecu, but it seems to stay on all the time even when the key is out!
StuBeeDoo
jondrift
can i use any switch for the job?
chrisr29
I took a feed off of the heated rear window switch. It was the only convenient thing I could find in the car that was a switched live.
Turbo-Brown
- Boost Junkie
I too would go for a relay which switches on with the key. There's a convenient place for the power to come from for the relay under the bonnet just next to the battery tray (either the battery itself or the distribution point for cars with the bat in the boot)
e30_Turbo
- Boost Junkie
FlappySocks
Use the connector under the battery tray. If you cut off the plug, it's the green and white wire. This connects to one of the relay sockets next to the expansion tank. If you have a relay missing, then it's that one it connects to. If you have three relays, then your in luck.
Stuart.
Stuart.
Motronic to Megasquirt Plug and Play Guide
