M40 turbo
chu346
Fri Oct 05, 2007 10:21 pm
Gonna be starting the 318ti project soon and have a few questions:
Where is the best place to take the oil feed from?
Where can I get a oil return pipe from?
What spark plugs do I need to use, do I need a colder set?
I'm looking at running 8psi to start with then going upto 14ish, MS will be going on in the next couple of days :D
fowler
Boost Junkie
Fri Oct 05, 2007 11:49 pm
oil feed sump as turbo will have to sit diffrently to a M20 turbo...
speak to ANTn he will tell all
EX A-Tech Workshop bitch !!!
gone but not forgotten
chu346
Sat Oct 06, 2007 12:20 am
No reply to email to Ant
fowler
Boost Junkie
Sat Oct 06, 2007 12:23 am
he has been a busy chap.
chu346
Sat Oct 06, 2007 12:40 am
That's why i'm looking for answers elsewhere
chu346
Sat Oct 06, 2007 11:08 pm
anyone?
fowler
Boost Junkie
Sat Oct 06, 2007 11:59 pm
no because i think he is prob the only one to do it!!!!!!!!!!!
Ant
Retired Team Member
Retired Team Member
Sun Oct 07, 2007 11:44 am
Chu, on the filter housing there is a blank fitting on the opposite side to the pressure switch, remove the 5mm hex head blank and thats where to take the oil feed from dude.
on the M40 the return has to go below the static oil level, not an issue though as its way above the oil level when the engine is running so the return will function as required.
HTH
cypriot_boy_2k7
Sun Oct 07, 2007 2:41 pm
i want a turbo :cry:
bmbartlett
Thu Mar 18, 2010 10:10 am
How did your turbo project go, did you come across any major issues?
chu346
Thu Mar 18, 2010 1:13 pm
It very went well, 190bhp@8psi
Have a read http://www.e30zone.net/modules.php?name ... hlight=m40
I still have the kit in the garage, may part with it for the riight price....
cypriot_boy_2k7
Thu Mar 18, 2010 5:23 pm
how much was he whole kit?
ross_jsy
Thu Mar 18, 2010 8:48 pm
don't take offence to this, but apart from the fact its different, why did you do it?
m52b28 with m50 inlet and cams with a remap would destroy that.
cool project though
chu346
Fri Mar 19, 2010 5:15 am
1) I would get 30mpg
2) I already had a turbo siting in the garage
3) My first setup only cost me a grand
4) The whole point of this car was to be lightweight and on a slim budget
5) Insurance was only £400
6) These engines are cheap to replace if I break it, I don't think I've ever seen one for sale for more than £100
7) For me this was easier than a M52B28 because I didn't need to source the parts, then mod the engine and then do the engine conversion
8) I don't believe that a M52B28 would destroy my old 1.8t when it was running 14psi
ross_jsy
Fri Mar 19, 2010 8:16 am
some good points there. so what power did it put out when you had it running at 14psi?
chu346
Fri Mar 19, 2010 12:39 pm
Didn't have it tested at 14psi. The dyno guy thinks it would have been upto 250bhp. I think it would be more like 220-230ish.
