what sort of bhp?
hass
hi guys currently im doing my turbo conversion as you might know from my previous thread
im using a later block with a 3mm decomp plate
42lb injectors
t34 turbo 0.63 hotside
people been asking me what bhp ill be push but i dont know what to say
any ideas
also what psi could i run on this set up
i know that bligsta got 224 bhp and 300 torqe on 7 psi
any way thanks
42lb injectors
any ideas
any way thanks
chu346
How much psi are you going to be running?
hass
i dont know
what can i run with my set up
fuzzy
the t34 itself will take about 28psi at its limit. i dont know how the rest of your engine will handle that sort of boost though.probably result in a big bang
hass
well a standard engine can take i think 10/12 psi i could be wrong
but im using a 3mm decomp plate so im guessing ill probably can do 14/16 psi
thanks hass
thanks hass
Gunni
if you got the head bolts and proper engine management you could
be seeing upwards of 350whp,
but more importantly what are the wheel sizes on the turbo you have,
Ant
- Retired Team Member
How much HP ? . Answer is more than stock with lots of torque Hass
Email FTW
fowler
- Boost Junkie
agreed with that man above ^^^^^^^ he knows !!!!!
EX A-Tech Workshop bitch !!!
gone but not forgotten
Demlotcrew
Yeah and what does all that torque equal? Lots of smoke and no go
fowler
- Boost Junkie
depends on ratios, what clutch is fitted etc.
but it would be great fun
O/t demlot how is the NA route treating you ???
Kos
come on ben, what up with your car ?? when we going to see it
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
soon enough all good things come to those who wait
KOS had any dealings with quaife ???
Demlotcrew
All is well ben
Im doing quite a few jobs on both cars at the same time, so its taking a while to get where i want to be but good things come to those who wait etc.
fowler
- Boost Junkie
yess indeed
o/t what sort of price to by an S14 engine these days
Kos
i'm not waiting for a good thingfowler wrote:soon enough all good things come to those who wait
re quaif , in what respect ?
have i used them or do i know of them or know some one in there ?
if so i can answer all 3 with a yes
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
need to have a diff made or use one of there ATB diffs.
just need to know what there like etc
Kos
cant fault them, the did a LSD for me in a fiesta track day car years ago, the car and box is still going strong. well worth the money, they build diffs for ford and that says it all really.
quality costs though
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
well i have sent them a query but no reply yet
been stocking up on parts to break them.
Demlotcrew
Well it depends there are so many different S14 versions thats its hard to estimate. But as you seen the last engine sold on here was 4k
There are TB's on ebay for £900, so they are going up on value!
You can get lucky and get one cheap but it will be worn/damaged.
Looking to get one?
Looking to get one?
Kos
never ever broken a medium case diff, and i've pushed them hard. its your rear beam and boot floor you got to worry about.
ATB will be better suited to a track, and not straight line abuse. anyway if i recall corectly quaife dont do guarantees on parts especially one offs etc
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
possibably
need to have a look at some stuff first turbo'd S14 poss
Kos
turbo'd S14's been done lots of time, i know of 2 UK cars. one belonge to a user on here called marty bee, estoril blue with 18" bbs rk's PBMW feature about 2 years agofowler wrote:first turbo'd S14 poss
thy second is a LOTEC conversion, T4 turbo, porsche external wastegate
400bhp and is a monster. specialist imported by MPC for the owner.
supercharged s14 had been done as well, featured by TBMW 5 years ago, built bt TDI ( wankers ) and now being re built
i know of an other possible s14 turbo in the making, so you've missed that boat fella
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
V8 twinturbo thats way to go
Kos
fowler wrote:V8 twinturbo thats way to go
easier said then done
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
like most things mate
need to do a bit of reserch 1st but it should be next years play thing.
Kos
s14 turbo, V8 TT..........fowler wrote:like most things mate
i'd get your m20 sorted 1st , or have you blown that up already ?
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
its a story mate !!!
an epic one but it will all be told
Kos
so you blew it up, and ants convinced you to chuck in a V8 from the lads in the unit next door ?fowler wrote:its a story mate !!!
IG Pukar.Designs
IG Pukar.Designs
fowler
- Boost Junkie
its a possiblity but who knows !!!!!!
