hi guys in the process of buying my parts for
my m20 2.5 turbo project
im gonna go for the standard engine the later version
now what sort of advice would you guys give on the decomp plate?
is it anygood?
or i was thinking bout the mls headgaskets too.
my original plan is the stanadrd o/s headgasket
does any 1 knw were to find these parts.
many thanks hass
decompression plate
maxfield
The later engine is 8.8.1 IIRC so you don't need a decomp plate really.
Unless you were running big boost but then you would get forged pistons...
isTURBO
hass wrote:hi guys in the process of buying my parts for
is it anygood?
many thanks hass
I know that Ant can get you a decomp one.
I think the o/s ones are available from the agents, though not sure.
If you are going for a high boost then the decomp would be the way to go, i guess.
selling more bunnies to pay for my conversion-
Ant
- Retired Team Member
I have 2 decomp plates in stock to suit M20 @ 84mm bore
£180 each, both new and un-used from Ferriday.
Email FTW
blingsta
- Boost Junkie
you will be able to run more boost but probably lose on low end grunt Hass..
