started me car for the first time since i strapped a turbo to it, and it started first time with the wasted spark all good, all of a sudden its misfireing, cylinder 3 and 4 are sparking but very weak, the rest seem very strong??
any ideas??
wasted spark problem
Colonel Sanders
- Le Surrender Monkey.
- Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
e30_Turbo
- Boost Junkie
Colonel Sanders
na no arcin, just really weak spark but the rest are fine? doin my head in!!
Ant
- Retired Team Member
Kevins old MS ?
if so, open the lid and check the coil ignitor wiring, there was a bad joint in the iirc dude, blob O solder should have it up and running OK again, if not replace the VB921Z ignitor FET and try again, they are relible units dude, but I have killed one with too much dwell so it can be done.
Email FTW
Dan318-is
I had a week spark on my wasted system and i grounded the coils inside the unit directly to earth and it solved the problem?
Like you say it provides a strong spark so a good earth is needed to provide sufficient dwell.
Colonel Sanders
cheers boys will open it up tomorrow an take a look..
