turbo oil return line...
- WARLOCKM42
- Contact:
Hi guys just wanted to ask if there is a way to return oil from turbo on a m42 engine without drilling the block or other parts .I i have to drill were is the safest spot to do it ???
- WARLOCKM42
- Contact:
Has to be higher than oil level...
E30Mark
Drill it into the top part of the sump....
PM for details
PM for details
Turbo-Brown
- Boost Junkie
- Contact:
It doesn't have to be higher than the oil level.
One of mine's well below it and I've had absolutely no problems whatsoever.
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
So did I.....till it melted......mattG wrote:I have a clear section of pipe in my oil drain & you can see the oil flow.
I've ended up with some 10bar hydraulic hose, very OTT but it works fine
Ow, a by the way, my oil return is direct into the sump, just over the oil level, no issus at all.
HTH, Mark.
Turbo-Brown
- Boost Junkie
- Contact:
Did someone say you were selling up Mark?
- WARLOCKM42
- Contact:
Ok thanks guys i guess i ll use a drill after all... oil sump is just fine...
I do not like football or basketball because they need one ball to play.I like drifting that needs two...
