so after playing around with it i've bodged a solution together. I tried normal idle valves off various cars but none would close enough to get a sufficiently slow idle speed. the separate throttles on my engine have their own bypasses to balance them against each other so the engine needs no extra air from the main idle screw once warm. so then I started playing with these...
they're fuel vapour control valves (or something like that!) from E36s. normally open but shut completely when shown 12 volts. unfortunately they don't flow very much air, so i've ended up using three - one to close or open the main idle air inlet, and two more to allow air into the engine separately when cold. they all open and close together from a switch on the dash, though i think the megasquirt could probably operate them if i knew more about it
looks like a right bodge at the moment, but seems to work really well. cold starting is still in the 1000rpm region, and once fully warm with the valves shut it's still 1000rpm which is good enough for me.
the valve on the right in the first pic is a bit better - it's larger and flows much more air. unfortunately it came off a merc C class and the breaker only had one of those in when i went.
also been fiddling with the rest of the inlet, it's had a crappy (tiny) air filter on since the turbo was fitted because it seemed like that was all that would fit; however Andy335touring let me try his old cone filter, which just fitted once I'd removed the front panel for better access!
old vs new (does the one on the left really look like a 300bhp plus filter
complete inlet up to the turbo compressor...
while the front panel was off i took the opportunity to remount the fan nearer the rad, which will hopefully mean faster cooling once it comes on - it used to blow loads of air around the rad instead of through it!
unfortunately i can't find out if the new inlet has made any difference yet because i'm putting a different water reservoir on to make it easier to bleed, and there's no coolant in it at the moment
