Waste Gate Chatter
mattG
Post Sun Sep 02, 2007 5:39 pm
Had my t3/4 turbo running for a little while @ 8psi approx. and the last few days the waste gate (which is internal) has become quite audible when comming off throttle any idears why?
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
Demlotcrew
Post Sun Sep 02, 2007 6:31 pm
The waste gate could be broke and thats the turbo that you might be hearing stalling.
HTH
Turbo-Brown
Boost Junkie
Post Sun Sep 02, 2007 9:34 pm
If the WG was broken, you'd likely as not be seeing more than your desired boost level.
If on the other hand you've got a dump valve which has failed, that could cause chattering and stalling.
mattG
Post Sun Sep 02, 2007 10:35 pm
Cheers guys,
On further investigation (on boost driving winkeye ), the BOV/dump valve is not as sharp sounding as usual,
I do quite like the waste gate sound but what damage can be done to the turbo by stalling, how can the waste-gate break do you mean the actuator?
(\__/)
E21 turbo
Turbo-Brown
Boost Junkie
Post Sun Sep 02, 2007 10:45 pm
If the WG was broken, you'd be seeing more boost than you should (unless the spring's broken that is in which case less.
Either way, the boost level would have changed if the actuator or WG had failed in some way.
mattG
Post Sun Sep 02, 2007 10:51 pm
Boost seems the same, i think it's pointing towards the bov, will this damage the turbo?
(\__/)
E21 turbo
Turbo-Brown
Boost Junkie
Post Sun Sep 02, 2007 10:59 pm
Probably not, it's not a bad idea to find out what the problem is and fix it though.
mattG
Post Sun Sep 02, 2007 11:21 pm
Will do Alex,
(\__/)
E21 turbo
