turbo pistons
hass
hi
i have an 1986 325i m20 engine which is gonna be my engine for the turbo conversion
but the engine is the high compression engine which the high comp pistons
now can i use the later type 1988> pistons in my early block?
would i need to modify anything i.e crank/conrods
what pistons rings would i need the ones for post 88 or pre 88 or are thay the same
many thanks hass
many thanks hass
isTURBO
hass wrote:hi
many thanks hass
Have a look using the search bar or alternatively scroll through this section and you will find tons of info.
Also give Ant at A Tech a call and try Blingsta whos extremely helpfull.
maxfield
It depends on how much power you want.
The early engines are 9:7:1 or something along those lines.
You could stick a de-comp plate in there.
I believe the pistons are different shapes so aren't interchangeable without machining work
blingsta
- Boost Junkie
Hass.. alot quicker, cheaper and easier to just get a late block mate
Kos
erel, the late blocks might be "lower compression" but that does not mean that its turbo ready
yes they are lower comp, but with a few ignition tweeks the high comp engine can take boost and be more responsive.
ultimately both block will crap them selves at boost over 7-10 psi and if used the way you really want to.
a decent set of pistions and ring IS the way to go
Turbo-Brown
- Boost Junkie
I think the early engine is limited by the amount of ignition advance you could run under boost.
Sure you can make good power with the early engine, but the torque's not gonna be as good as it could be if you were to run more advance and also, if you keep turning the boost up and retarding the ignition, you're gonna drop an exhaust valve into the engine
blingsta
- Boost Junkie
Reason i said complete new block Kos is because he has the early block there but he reckons the rings have gone and might also have piston slap, so rather than spending money on recon'ing that block, i reckon its cheaper and quicker to get a later 2nd hand one.Kos wrote:erel, the late blocks might be "lower compression" but that does not mean that its turbo ready
Kos
what i was getting at he may as well re built it to a proper low comp engine with a set of forged JE pistons for example, with total seal rings and not use standard parts, they dont last in the long run.blingsta wrote:Reason i said complete new block Kos is because he has the early block there but he reckons the rings have gone and might also have piston slap, so rather than spending money on recon'ing that block, i reckon its cheaper and quicker to get a later 2nd hand one.Kos wrote:erel, the late blocks might be "lower compression" but that does not mean that its turbo ready
that is if he's serious rather than but a second hand "so called lower comp" engine
did you think i ment for him to re build his engine using standards parts ?? you should know me better that that, to assume that.
surj
well how bout if you used the later block with the the eta gasket thats normal gasket + 3mm thicker what sort of boost do recken could run on that
Kos
using a thick head gasket is NOT the way to low comp your enginesurj wrote:well how bout if you used the later block with the the eta gasket thats normal gasket + 3mm thicker what sort of boost do recken could run on that
how thick do you think the eta garket is ??
Ant
- Retired Team Member
ETA gasket is same as any other 84mm unit for the M20 series 1.63 or 2.03mm iirc
100% agreed with KOS ( is that a 1st ?
) skrimp now, PAY later.
JE/Ross pistons are £Â£ but forged and strong as hell, you could argue the crown shape wont match the CC shape but thats open for debate, total seal rings are a good investment though, zero blow by results in lower crankcase pressure and better cylinder filling per crank revoloution.
you could achieve the same with spark eroded std items and retain the CC shape as OE but the squish will have changed...
lower CR + turbo = more lag, less midrange and possibly more top end power due to the ability to hike the ign advance a few degrees over the higher CR units.
Overall power could be the same, just the curve will have changed shape and show more peak @ the top end.
^ only my opinion/experience though, not to be taken as gospel
BIG gasket = bigger weak area, MLS/copper or otherwise, but is that a bad thing ?
you could look @ the H/G as a safety valve, beats a rod through the block
Email FTW
Turbo-Brown
- Boost Junkie
On the total seal rings topic, haven't lots of people had real trouble seating these properly meaning the cylinders need honing again and a new set of rings needs fitting.
Presumably the way around these problems (as with any rings for that matter) is to follow the high load break-in routine, but the problem is that on an unmapped engine you can't really be applying lots of load.
Ant
Hi Load indeed M8, they break in lovely though
I only know of one set being replaced due to oil loss, @ 10K iirc.
Email FTW
Turbo-Brown
- Boost Junkie
Probably one of those things that must be done otherwise you're buggered.
I've seen a couple of newly built engines smoking like fork with these rings fitted and can only assume the owners namby pambied the break-in.
Ant
Pussies
I run mine in before handing them over to the owners to play with, I use the fast method
no sense messing around eh !
I have 3 turbo beasties to run in in the next 3 weeks, thats not as much fun
Email FTW
