Hello, have you done the M30 engine transplant on an E30? If you have did you have any problems with the exhaust manifold on the steering colum?
Many thanks
Grant
Whos done a big six engine swap?
whipsey
loads of conversions being done at present mine included do a search you will be suprised
Toby_Unna
- Boost Junkie
as long as you use the e34/e32 manifold (just use the whole engine!) the worst you'll get is a little contact from one of the cast downpipe clamp joints touching the steering column damper heatshield on left turns. this can be adjusted out easily
