megasquirt
staffy
can some one tell me the pros and cons of megasquirt! i belive at the moment i am running deleted maf with custom remap is megasquirt the way forward and how much would it cost
m-dtech
- Unapproved Trader caution
CHRISP
- Boost Junkie
e30_Turbo
- Boost Junkie
There aren't any cons as far as I know, just pro's really.
With MS you get full control of both fuel and sparks along with a few others if you choose too.
It allows you to run different types of ignition and injectors along with control for things like boost, water injection, nos etc etc
The initial costs are low and with some thought and preperation you can build the ECU yourself in a few hours, I did and I'm no sparky.
You need the basic sensors and a few toys but overall it's got all of the features you could possibly want and more.
Along the same idea is VEMS and SPECTRE which are slightly more upmarket versions coming with more built in parts, less hassle for masses.
PM Ant for any prices etc,
HTH, Mark.
HTH, Mark.
FlappySocks
For the cherry on top - don't forget to add Wasted Spark to your shopping list of parts - costs about the same as a new dizzy cap. I made my MS from scratch, and it's brilliant. No negatives I can think of, except for the steep learning curve... you really need to do your homework.
jkarran
It doesn't do non-wasted spark 4cly coil on plug ignition without modification (or at least it didn't a few months back when I looked). Not a problem for NA engines but possibly an issue if you're building a supercharged motor.
jk
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
staffy
thanks guys what sort of price did it cost u for the system i have seen one for sale that has been set for the 2.7 and should do me well just wondering how much i should pay for it
Toby_Unna
- Boost Junkie
one major plus, aside from the performance/response improvement is that it's a brand new EFI system, loom, ecu etc replacing 20 year old stuff. so you suddenly stop having daft problems like hunting idle, misfiring, non starting etc
mine has been the most reliable car i've had since the MS went on, it never ever runs anything other than perfectly
Motronic to Megasquirt Plug and Play Guide
