m60b40 v8 swap step-by-step
is it hardto put a m60 to an e30?Also if anyone has some detailed story of a similar swap or a walkthrough it would be great.
- Kos
- Contact:
its no easy task
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
maxel wrote:, compared to m50, what do u thinkKos wrote:its no easy taski want these 282hp soooo bad :'(
never done an m50, but judging how popular its getting its cant be too difficult, where as i know of one m60 v8 .
so if an m50 is 4/10 on the difficult scale a v8 would be 7.5/10
you can get an m52 2.8 up to 250bhp which is very lively in an e30
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
what, to get 250 bhpmaxel wrote:with expensive mods yeah... ?
2.8 from e36
2.5 inlet manifold and throttle body form e36
us spec e36 m3 cams
re-map
cost maybe £2500 including getting your engine
V8 and six speed box aint cheep, lots of fabrication, manifolds to worry about, brakes and servo issues ? costs , lots more i recon
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
goes with out saying they help, i wont include them into any conversion cost as you'd do them to any car!maxfield wrote:Decent filter and exhaust?Kos wrote:what, to get 250 bhp
2.8 from e36
us spec e36 m3 cams
re-map
IG Pukar.Designs
IG Pukar.Designs
Gravy
I'm trying this conversion very slowly and it is tricky. I haven't even got into the tough stuff yet, and as Kos says, brakes and gearbox are the biggest bugbear. 6 speed g/box is a) extremely rare and b) about £1000 if you find one unless you are seriously lucky and find a breaker who doesn't know what they have got.
However, where there is a will there is a way and they can be made to sound amazing. BMW really muted the engine with there exhaust system, paricularly on the 7 series (quite understandably for a luxo-barge) where my motor came from.
Do a search for BMW V8 on youtube and or BMW E28 V8, listen to those puppies sing and be inspired!
glenn
- Engine Transplant Services
http://www.e30zone.net/modules.php?name ... pic&t=2882maxel wrote:is it hardto put a m60 to an e30?Also if anyone has some detailed story of a similar swap or a walkthrough it would be great.
yeah you can mod a 2.8 6 pot but you can't argue with 286bhp and 295lbs. Can you? You's need a super charger or turbo to get the 2.8 going like that.
If done properly it would be the most drivable conversion out there! V8 grunt, no bodged turbos on 2.5's or £3000 S50's or big heavy S38's. They are a fair bit lighter than the M30 boat anchor and won't be hanging over the front axle. Just a simple 4 valve V8 that on the whole is a good engine and won't do head gaskets like the M62, bar Nikasil!
You don't have to use the 6 speed box as the far more common 5 speed from the E34 530 v8 bolts straight on
This is the conversion i'd like to do once the pina is done, so a long way off then!
this is my one.
Not on the road but it is a driver. going to transfer it all into a 3dr
For some reason the link don't work properly, try this http://translate.google.com/translate?u ... uage_tools
hmmm i want to do it, but also live in iceland (so wont be buying an enigne from u) and this is so rare swap or something, nobdy has ever covered it in extreme detail like u can find with the m50 and m30
Axel
BMW 320i Touring (M20B25 RD Headers)
- james_obryan
kos thats not 250 bhp. Maybe add a set of m3 manifolds and you would be there.
- Kos
- Contact:
got it done on my mate e36, 251 bhp on standard exhaust manifolds. they flow pretty well from factoryjames_obryan wrote:kos thats not 250 bhp. Maybe add a set of m3 manifolds and you would be there.
IG Pukar.Designs
IG Pukar.Designs
- james_obryan
I know people with all the above mods apart from the cams that are making about 40 bhp more than stock, so are you saying that the cams add another 50% i.e. 20 bhp when combined to all the other mods. Thats only 35 bhp shy of the 3.0 m3 with its manifolds and higher compression and advanced vanos
- Kos
- Contact:
193 plus the 40 hp gain with out cams comes to 233, leaving you 17 hp short of 250, considering you will have a less restrictive exhaust and some sort of induction going on i dont think thats unreasable claim, and its not a claim, its factjames_obryan wrote:I know people with all the above mods apart from the cams that are making about 40 bhp more than stock, so are you saying that the cams add another 50% i.e. 20 bhp when combined to all the other mods. Thats only 35 bhp shy of the 3.0 m3 with its manifolds and higher compression and advanced vanos
ss for being only 35-40 hp shy of the M3, why do you thing the 328i sport was retricted to 193, cheaper insurance and to not make the M3 look only a bit better.
a simple re-map on a 328i sport puts it up to 210-215 bhp
IG Pukar.Designs
IG Pukar.Designs
