clinick
maxfield
Post
Fri Jun 22, 2007 3:56 pm
There is hardly anything you can do apart from chip and altering cam timing.
I've searched and searched.
ed325i
MJG
Post
Fri Jun 22, 2007 7:38 pm
Just fit an SR - it's easy and powerful! Modifying the M40 will always be hard, just get whatever's easiest for you in Thailand.
If I couldn't find big capacity BMW engines for £200, but could get an SR for £500, then I'd just go with that!
toby
Post
Sun Jun 24, 2007 1:20 am
I've wonder what a stanalone ecu like megasquirt would do for one of these. You could get one sent to you and set it up yourself.
- Homo Hair
Post
Sun Jun 24, 2007 8:11 am
old skool rim!
megasquirt, cam and exhaust is bout as far as it might go.. Headwork also i guess
m-dtech
- Unapproved Trader caution
Post
Sun Jun 24, 2007 8:51 am
first thing id do is loose the wooden wheel and knob, thats gotta be worth 10bhp lol
Post
Sun Jun 24, 2007 9:11 am
Is your windscreen tinted?
Best thing to do with the M40 is get it out of your engine bay
Andyboy
- Alpina Colada
Post
Sun Jun 24, 2007 10:45 am
The M40 can be modified. Piper Cams do two camshafts, a 270 degree fast road and a 285 degree 'wild' stick. They quote 10 bhp and 14 bhp for these, but I'd use the 270 cam with a decent chip - should be good for 130 bhp. A bigger bore throttle body would be next. Change the cam along with the rockers, rocker pads (between the rocker and the valve) and the hydraulic lifters as well as the cambelt and all three rollers. That would sort out all the M40 issues and make it a pretty decent engine. The M40 is really a bag of shite in old age but one in perfect nick is a pretty good engine.
clinick
Post
Sun Jun 24, 2007 11:06 am
Thank you for all suggestion. So I should change camshaft and chip? I know only Dr. Schrick camshaft. Does anyone suggest me another brand?
Post
Sun Jun 24, 2007 11:09 am
reckon there would be anything to gain by fitting throttle bodies/ bike tb's and a standalone engine management?
m-dtech
Post
Sun Jun 24, 2007 11:20 am
clinick wrote:Thank you for all suggestion. So I should change camshaft and chip? I know only Dr. Schrick camshaft. Does anyone suggest me another brand?
Andyboy just quoted "Piper Cams"
ed325i
e30bmlover
- Ac Schnitzer prophet
clinick
Post
Sun Jun 24, 2007 12:14 pm
m-dtech wrote:clinick wrote:Thank you for all suggestion. So I should change camshaft and chip? I know only Dr. Schrick camshaft. Does anyone suggest me another brand?
Oh! sorry. This is a problem for me because I always call the body and engine parts in Thai language. When I saw the words that you wrote, I look up in google search for the meanings and pictures.
5 minutes ago, My friends called me that he can find another Hartge' parts for me. It's time for spending money again
CHRISP
- Boost Junkie
Post
Sun Jun 24, 2007 6:16 pm
Turbo 170 bhp +
318 turbo cab mint for sale offers
snoops
- Major Helmet
Post
Fri Jun 29, 2007 11:04 pm
Andyboy wrote:The M40 can be modified. Piper Cams do two camshafts, a 270 degree fast road and a 285 degree 'wild' stick. They quote 10 bhp and 14 bhp for these, but I'd use the 270 cam with a decent chip - should be good for 130 bhp. A bigger bore throttle body would be next. Change the cam along with the rockers, rocker pads (between the rocker and the valve) and the hydraulic lifters as well as the cambelt and all three rollers. That would sort out all the M40 issues and make it a pretty decent engine. The M40 is really a bag of shite in old age but one in perfect nick is a pretty good engine.
how much power would all this roughly give + cost ?
