Recomend a wideband
appletree
Post Mon May 28, 2007 9:09 am
Can any one recomend a wide band sensor and gauge for me, dont realy know what i should be looking for in one so if anyone can offer some advise or linkls that would be good.
cheers matt :D
liam012
Post Mon May 28, 2007 11:34 am
well i dont know much but i have the innobate lm-1 and digital display box and it really is easy to use.
i dont know what more one can want out of a sensor but it seems relatively tough and simple to setup. hth
Ant
Retired Team Member
Retired Team Member
Post Mon May 28, 2007 12:59 pm
Lm-1 from me, good plan lol !
can supply XD-1 too if you're wanting ( 52mm guage format )
Gunni
Post Mon May 28, 2007 2:18 pm
Zeitronix for me,
Was voted best wideband by some sport compact magazine in the US.
They are awesome :)
Gunni
@ 2012 VEMS group buy !!
Ant
Retired Team Member
Retired Team Member
Post Mon May 28, 2007 2:24 pm
Matt, you're using Emerald yeah, so you can just purchase a Bosch LSU4 WB and plug that straight in, no conditioning circuits required or external controller.
appletree
Post Mon May 28, 2007 6:30 pm
hi ant, i am going to be using emerald but i would perfer to have a gauge on the dash to display whats going on just for piece of mind, the sensor would not be linked to the emerals and not used to map against although dave will be using one to set it up the first time :D .
if all seams to be happy after the mapping i may take it out but would quite like to be able to plug it bk in agian if some thing was knocking etc....
Can you post some pics or a link to the 52mm gauge you could supply please Ant?
chu346
Post Mon May 28, 2007 7:05 pm
Gunni wrote:Zeitronix for me,
They are awesome :)
Why are they awesome?
Turbo-Brown
Boost Junkie
Post Mon May 28, 2007 7:49 pm
I'm about 99% sure the Emerald still needs an external conditioner I'm afraid :(
appletree
Post Mon May 28, 2007 9:36 pm
Not to sure what you mean by a external conditioner??? :?
Dan318-is
Post Tue May 29, 2007 12:39 am
Surely emerald would need a lamdba to run? It must have some sort of feedback?
Most people on Ms tend to use lc-1 innovate widebands it seems, can be picked up for abuot 135 smackeroos eitehr from bill shurvinton of the e-gay.
Gunni
Post Tue May 29, 2007 2:53 am
They are awesome :)
Simple, Easy, Can log EGT and Boost, rpm, throttle as well,
more here
http://www.zeitronix.com/Products/zt2/zt2.htm
Gunni
Turbo-Brown
Boost Junkie
Post Tue May 29, 2007 10:17 am
You can run any of the aftermarket ECUs without any form of feedback. Someone maps it for you using a WBO2 kit and then walks away taking their kit with them to work on someone else's car.
Emerald and most of the ECUs available need a signal conditioner which takes the signal coming from the sensor itself, and gives a voltage output ranging from 0-5v which corresponds to the AFR. In either the WBO" software or the ECU software you need to make sure that the voltage values correspond to the same AFR.
Just looked at the Emerald leaflet for the new K3 and it does say you need an conditioner, but if you've got one it can self map with the same sized table that the normal fuel table uses so it should be pretty good.
I would say though, that you shouldn't really be looking at an AFR gauge whilst driving! Leave that to someone else or a computer and tuck it away out of sight. If your mapping's right you don't need to see it and likely as not, full load is when it's reading is going to interest you most.....which is exactly when you should be looking at the road. :)
Morat
Post Tue May 29, 2007 3:56 pm
so just leave it logging away and don't bother installing the gauge on the dash :)
Dan318-is
Post Tue May 29, 2007 3:58 pm
Morat wrote:so just leave it logging away and don't bother installing the gauge on the dash :)
Autotune :)
e30_Turbo
Boost Junkie
Post Tue May 29, 2007 4:17 pm
Autotune :)
Be carefull with the autotune as it needs setting up before it will work properly. The stock settings are only for N/A cars and only cover a small part of the map. The theory behind it is sound but the actual use of it in real life is still under debate by the masses.
HTH, Mark.
Dan318-is
Post Tue May 29, 2007 4:21 pm
Its been set up and used on my ECU before. Im yet to actually purcahse a wb02; there was a guy on msefi that had one for dirt cheap but he hasnt replied to my pm's :(
e30_Turbo
Boost Junkie
Post Tue May 29, 2007 4:53 pm
Dan,
I've got 2! but ones fubar, it should be going back to innovate for a refurb soon, I'll either sell it on or keep it when it gets back.
I can reccomend the VW speed shack in Manc, they were doing them for about £150 inc vat.
VW Speed Shop
47b Kingshill Road
Charlton Cum Hardy
Manchester M21 9HD
United Kingdom
44 161 8815999 - Speak to Paul.
If you need any help wireing or setting it up let me know.
HTH, Mark.
Dan318-is
Post Tue May 29, 2007 4:57 pm
Hero! Bill shurvinton said he would sell me one for 135, the guy on msefi only wanted 105 delivered!! But he hasnt replied yet :( Thanks for the offer! should be purchasing one when i get back from holiday and leman at the end of june :cool:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue May 29, 2007 5:03 pm
Are we talking 135 for sensor and control box?? everything ?
Dan318-is
Post Tue May 29, 2007 5:04 pm
hoshy wrote:Are we talking 135 for sensor and control box?? everything ?
Yeah lc1 innovate the whole package i think! go to www.msefi.com and PM bill shurvinton.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue May 29, 2007 5:08 pm
bargain. last time I checked the lc1 was 250 all inc.
Assault
Post Tue Jun 05, 2007 12:54 am
I'm running a Zeitronix simply for the added logging features. If you are running an aftermarket ECU then there may be a specific brand of wideband sensor that will be recommended or set up for running with your ecu. Otherwise the LC-1 is a good catch for an all in one or the Zeitronix is also good. I cant comment on the Emmerald though.
Turbo-Brown
Boost Junkie
Post Tue Jun 05, 2007 8:12 am
Think as long as you can either configure the V-in/AFR in the ECU, V-out/AFR in the WB controller or both then you can use pretty much any combination of WBO2 and ECU :)
Andy335Touring
Post Tue Jun 05, 2007 6:41 pm
Turbo-Brown wrote:Think as long as you can either configure the V-in/AFR in the ECU, V-out/AFR in the WB controller or both then you can use pretty much any combination of WBO2 and ECU :)
Theres a table for V's/AFR on my old style Emerald so i guess the new one will ?
My Inovate WB has a little control box which i think you can't really do with out due to the heat cycle set up and free air calibration, both which add to the long term accuracy of the out put. It also can give you fault codes to help diagnose any problems more quickly.
Turbo-Brown
Boost Junkie
Post Tue Jun 05, 2007 9:02 pm
Yeah, you get a little graph with the new one I think :D
appletree
Post Wed Jun 06, 2007 10:29 am
this is abit more what i had in mind, a guage you could just look across, not overly botherd about being able to log and then connect to the PC.
what you think?? :D
bit steap n the price though! :cry:
http://cgi.ebay.co.uk/AEM-Uego-Gauge-Co ... dZViewItem
appletree
Post Fri Jun 08, 2007 5:38 pm
incase anyones intrested ive just bought one of the above for £140 brand new, deliverd and insured from america
let you know how i get on when it gets here! :cool: :D
FlappySocks
Post Fri Jun 08, 2007 5:41 pm
Does that include import duty & VAT?
appletree
Post Fri Jun 08, 2007 6:38 pm
as far as i can see the job lot i emailed the bloke and asked him how much to send the hole thing, P&P, ins the lot
he said £140-$280
http://cgi.ebay.com/ebaymotors/ws/eBayI ... mot_widget
Rallyprep_UK
formerly Driftnething
Post Fri May 09, 2008 9:59 pm
correct me if i am wrong but the honda civic type r 2001 type (k20 engine) uses wideband o2 as standard.
Try a breaker yard like where i work ! probs looking at no more than 40 quid and if you ask nicely they might cut it out for you so that you can adapt it to your vehicle.
www.combellack.co.uk
i dont have any at the mo tho :(
FlappySocks
Post Fri May 09, 2008 10:16 pm
You may need a wideband controller too, which pushes the price up.
ShepsEvo3
Master of go faster
Post Sat May 10, 2008 11:05 am
I'd be wary of the LC-1... I have mapped alot of cars with these fitted and comparing to my dyno wideband most readings seem to be out. And no, it's NOT my dyno wideband which is out! lol.
In my experiance it usually reads leaner than what the actuall AFR's are. so not in an unsafe way. This is usually caused by a faulty sensor.
www.sabre-tuning.co.uk
FlappySocks
Post Sat May 10, 2008 11:24 am
I read somewhere that the LC-1 needs regular calibrating.
Andy335Touring
Post Sat May 10, 2008 2:19 pm
ShepsEvo3 wrote:I'd be wary of the LC-1... I have mapped alot of cars with these fitted and comparing to my dyno wideband most readings seem to be out. And no, it's NOT my dyno wideband which is out! lol.
Dave Walker said some thing similar when i had mine mapped, i think they're OK to get your fueling 90% there if your going down the DIY route, but get it checked on a RR with a more profesional(sp?) WB02 kit.
I going to use mine to compair two different air filter set up's and log the AFR's on a few WOT pull's(on the road) as it should pick up if there's much difference. Richer = worse air flow Weaker = more air flow(= more power, touch wood :) )
Shame i never had the chance to see how accurate my LC-1 was against Dave's WB02, but i'd lent my LC-1 to a mate at the time.
ShepsEvo3
Master of go faster
Post Sun May 11, 2008 10:43 am
I also found that they are particularly susceptable to heat too. But this is just my experiance :wink:
