hi all
im in the middle of fitting ms to my car its a 87 325i turbo and was wondering where the trigger wire goes as ive put it in the wrong place. has anyone wired the ms loom into an ecu plug as this is what ive done if so can anyone tell me what pin it is?
thanks for your help
quick ms question
Ant
- Retired Team Member
pins 47 and 48
wire the trigger in blue to yellow, and red to black.
check comms, crank engine, no rpms... reverse wires , repeat the cranking test.
I Emailed this to you last week, did you not recieve it dude ?
**** EDIT***** '87 ECU with part number ending 073 ? or 173 3 row 55 pin connection ??????
if its an 073, then the trigger from a post 88 car will be required, rob the front pulley and crank sensor from any post 88 6 cyl car, and retrofit( all swop in easy), then connect the MS trigger to the "new" plug( tip: a cutoff OE TPS plug is spot on.. ) and crank again.
HTH
HTH
Email FTW
Gunni
Don´t you think a complete screened cable is better?
totally easy to find in a junker.
Ant
trigger cable is screened in the loom dude, on both MS and OE
Email FTW
Gunni
I tought you meant to cut the connector of the TPS and use new unscreened wires to the MS.
basil
i dont have pin 47 on my loom so i guess its a trip to the scrapper at the wkend! nah i missed that one ant dont no what happened there.
while on ms does anyone no of a good reliable usb adaptor as i dont have the serial port on my laptop?
thanks
thanks
basil
can you please tell me what tooling is required to gat he pulley and sensor of and is it a long job?
thanks
thanks
Ant
13mm socket and 4" extension is all you'll need fella
bit of a backache job but an hour tops will rip the required parts from the donor.
fit the new 60 tooth trigger wheel and VR sensor to your block( the holes are there already.. ) and wire the sensor in.
mystery solved maybe dude, how did we/I miss the pre facelift part
Email FTW
basil
sweet cheers mate it was just so i could go down the scrappy prepared! i may sound dumb now but where bouts are these parts located on the engine!
i duno mate its one of them things not to worry though. its getting there though ive got power and tps + other sensors soughted just no spark yet
thanks
thanks
