How accessible is the M30 starter motor in an E30? Im wondering if its worth replacing it before I drop the engine in. I assume the alternator is not a problem. Water pump is already done. Anything else?
Stuart
335i Starter motor
FlappySocks
DRIFTBOY
It's not too bad to get too, I've know plenty worse anyway.
I would crack the bolts off and nip them back up, so if you do ever need to take it off they shouldn't be too tight.
Could be worth putting on a new sump gasket, that would be a real pain to change later on.
Martin.
Martin.
FlappySocks
Good idea, thanks. Sump gasket already done. I assume the alternator is easy to get to.DRIFTBOY wrote:I would crack the bolts off and nip them back up, so if you do ever need to take it off they shouldn't be too tight.
Martin.
Stuart.
DRIFTBOY
Yeah, alternator is easy!
Martin.
Martin.
Motronic to Megasquirt Plug and Play Guide
