the isuzu 2.8 TD engine - anybody knows about it?
Locked
michael24m
Thu May 03, 2007 11:21 am
hi all,
i'm wondering if anyone can help with a bit of advice regardin this type of engine. '1996 2.8TD isuzu
is this by chance the interference type? with the valves entering the piston chamber?
it's not about the e30, but if someone is a mechanic, and heard about it.
thanks!
stonesie
Thu May 03, 2007 9:36 pm
Because of the compression in diesel engines i think they are all interference, the available space between piston and valve can be less than 1 mm :!:
michael24m
Fri May 04, 2007 1:25 am
thanks!
i tought the belt broke. but fortunatly it didn't! i inspected the belt and it is ok, it's another problem. pfiu! 8O
kam-325i
Fri May 04, 2007 7:33 pm
If you've got the horrible knock coming from the engine, check the timing on the diesel pump.
koos
Fri May 04, 2007 7:55 pm
I thought those were timed with gears?
kam-325i
Fri May 04, 2007 8:00 pm
koos wrote:I thought those were timed with gears?
I know some are driven off the cam belt.....
koos
Fri May 04, 2007 9:42 pm
So which is it?
kam-325i
Fri May 04, 2007 10:16 pm
I would not know, never seen the 2.8......but the 2.2 is driven of the cam belt.
Althought he has not said what the problem is yet........
stonesie
Sat May 05, 2007 2:44 pm
the 2.8 is a belt... im 99% sure i saw it in the autodata book when i was looking up my izuzu engine :?:
JJ26
Thu Jun 14, 2007 7:04 pm
The engine your talking about came in 3 sizes, 2.5 2.8 and 3.1. As far as im aware all 2.5 and 2.8 are cambelt driven. To know for sure just look at the housing between water pump and sump. If its gear driven it will all be alloy. The belt type have a 2 piece black plastic cover. Hope this helps.
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
Locked
