YB Cosworth Swap
ShakeyC
Tue May 01, 2007 1:05 pm
Hello E30's,
I am looking to buy an E30 in the near future, but all seem underpowered, so im thinking along lines of turbocharged engine i can use in racing/trackdays. What would i need in terms of parts and modifications to drop in a YB 200 or 205 block? is there a particular model of E30 which makes for an easier conversion or does it no matter?
ShakeyC
Tue May 01, 2007 1:13 pm
speak to a zone member called Fuzzy, he is running a YB turbo setup
you are best off starting with a 325 or a touring as they have better suspension & brakes
midnight
Tue May 01, 2007 4:14 pm
yeah well apparently the yb will drop straght in with very little worries, but what you ned is the front of the cossie prop and the back half of the bmw prop, to mate them together,
ShakeyC
Tue May 01, 2007 4:24 pm
Gearbox is somewhat of a mystry to me :?:
maxfield
Tue May 01, 2007 4:30 pm
Fuzzy has the T5 box linked to half a ford propshaft and the half going to the diff BMW
tim-ix
Wed May 02, 2007 4:24 pm
Recoprop are the people for propshafts.
Reco Prop (UK) Ltd
Chase St, Luton, Bedfordshire, LU1 3QZ
01582 412110
I have no connection with this business, just heard lots of good reports over many years.
ShakeyC
Wed May 02, 2007 7:26 pm
Im familiar with Reco Props already bit of a no brainer. How do i get in touch with the "Fuzzy"
maxfield
Wed May 02, 2007 7:27 pm
PM or FAO
fuzzy
He who sleeps with "Gingers"
Wed May 02, 2007 8:32 pm
hello mate, another would be convert to cossie power i see. excellent :D the 200 block is regarded as the strongest and best block to start with.as said i have the cossie engine,t5 rwd gearbox mated to the original e30 lsd witha custom prop,cosworth at the front and bmw at the rear all balanced and ready to go for £90 from a company in falkirk called Propshaft Services .there is a few issues to sort out along the way but nothing drastic.i payed £2600 for labour only to fit the engine as i already owned all parts needed but if you need to buy everything then budget another £3000-£4000+ for decent engine,turbo,gearbox,cooler,rad,ecu,loom etc. pm me if you want more details :thumb:
ShakeyC
Thu May 03, 2007 5:00 pm
WOW you actually done it, whats it like handling and performance wise? what sort of issues did you encounter?
Labour wont be a problem doing it myself on the weekends, i roughly know how much the donor parts will be (dabbled with yb's before) Physically fitting it in an e30 i can do mounts, brackets and linkages, wiring and all that if i know what needs to be done; any hints be handy mate.
Fuzzy your car is mega :cool:
bigj
Fri May 04, 2007 7:10 pm
found a step by step guide with pics
this guy used to post on here and passion ford
hth
http://www.e30cosworth.co.uk/
fuzzy
Sat May 05, 2007 2:01 pm
bigj wrote:found a step by step guide with pics
hth
iirc paul did his slightly different to mine as i used the original brake servo and fabricated a new alloy sump to fit around the front crossmember rather than alter the steering or crossmember.i also used the 4wd turbo manifold rather than the 2wd as it fouled on the inner wing.my front chassis legs were cut and reshaped to allow a 2wd rad and intercooler to fit.i also kept the original e30 hydraulic clutch rather than use the cosworth clutch cable by welding a mounting bracket to the cosworth t5 gearbox housing. (although i refer to it as " i used" the work was carried out by a garage for me) winkeye
johnna
E30Zone Irregular
Sat May 05, 2007 6:38 pm
[quote="fuzzy"] the 200 block is regarded as the strongest and best block to start with. [quote]
I thought the 205 had the thickest walls...
Certainly prized for the 2.1 built pintos.
Be a man for once in your life and sh!t in that boot!- Wilfred.
cecotto_singh
Sun May 06, 2007 12:42 pm
200 block is the strongest and the only way to go if you want big bhp? although 205 good for up to 400bhp which is enough in the e30s, trust me i know!
fuzzy
Sun May 06, 2007 2:08 pm
hth
he is paulsimon8 on here and graceland on passionford.the car is now owned by 'e30cosworth' on the zone.
ShakeyC
Sun May 06, 2007 5:18 pm
Rightyo im convinced with the YB is the best way to go, i be getting on the hunt for the bits i need, including the car. Fuzzy i assume you wanted to keep the e30 hydrualic clutch as its lighter and usable everyday rather than the ford cable one?
fuzzy
Sun May 06, 2007 5:21 pm
no i kept the bmw hydraulic clutch because the last time i had a cossie conversion done on a toyota celica the clutch cable snapped every couple of months.even heavy duty ones.
bigj
Sun May 06, 2007 9:55 pm
This lot would be a good start
no conection with seller
was going to buy this but wifeyshe say no no no
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ename=STRK
fuzzy
Sun May 06, 2007 10:04 pm
bigj wrote:This lot would be a good start
listing has been removed :?
bigj
Sun May 06, 2007 10:10 pm
ShakeyC
Tue May 08, 2007 1:03 pm
I got my eye on 2 e30 local to me a 325 going for £700 and a 318 estate for £1150 both 89 models in black. Also have an engine lined up its a small turbo t25 from a soon to be broken escort cosworth but it hasnt got ecu or looms, no intercooler or rad so i cant see it running he wants £1600 for the engine, turbo, mtx75 box :?
Nickk
Wed May 09, 2007 10:18 pm
Hi with regards to a small turbo engine (t25) its better to use a marelli loom and ecu set up( from any saff cos or a new pectal loom ) its a better setup and alot easier to get 350+ bhp and also the engine looms in a escos are built into the full car loom and would be a pig to separate
