Hi all,
I'm curretly looking for a turbo for my conversion.
Currently tyhe block has been o-ringed with low comp pistons (8:1) and head has been welded etc. (M20b25)
I'm aiming for 350bhp (apprx 1bar of boost)and was planning on using a H1C however can't find one in the Uk.
I have searched on ebay and foung the following turbos what are your opinions,
1)
http://cgi.ebay.co.uk/cosworth-rs-turbo ... dZViewItem
Bit worried that the turbine housing is too small?
2)
http://cgi.ebay.co.uk/Garrett-T4-TurboC ... dZViewItem
not sure if the turbo charger is too big
Also does any body know a good website for maps, ive done the calculations (pressure ratio etc) but would like addtional advice.
Many thanks
Turbo selection
oldroydsr4
bump
fuzzy
i believe the t34 with .48 housing is good for about 360bhp.not sure about the t4.
oldroydsr4
cheers fuzzy, what boost are you running?
Ant
- Retired Team Member
you need a bigger hotside to get 350 HP dude
I can source an HX40 with 19cm housing if you want dude, and I've realised I still have to supply a quote on the manifold
I'll do both in the am and shoot them to ya dude
Email FTW
fuzzy
17 psi at the moment but my t34 is capable of 27psi and around the 360-370bhp.stage 2 with 360 bearing and cut back blades. .48 same as the one your looking at. the t34 with .63 housing is good for about 400bhp im told on cosworth 4 pots.. im sure the t4 is smaller than one of the holset types frequently used by the e30 6 pots.
Ant
T34 with 0.63 hotside is borderline for the required output, dont forget a 6 cyl has 2 more power pulses to drive the turbine with, so whever works for a 4 pot is 50% too small for a six pot( simplification but you get the gist...... )
H1C, HX35 or HX40
18-19cm housings,
A pukka hybrid as per Dimmy's Sport is a lot of coinage, a few squid short of a bag-o-sand !
XS-power turbos( or similar Ebay TAT ) are NOT worth the risk !
H1C, HX35 or HX40
18-19cm housings,
Email FTW
oldroydsr4
Cool, i was going to avoid xs like the plague.
Will a T4 be ok?
Or should i just by a H1c from he U.S, as i can't really afford 1K for the turbo(my project will never get finished.)
Will a T4 be ok?
Ant
T4 is OK, but a very old design, the modern derv turbos are more efficient than anything else on the market.
Email FTW
oldroydsr4
I guess i'll, have to get a holset then.
Do you have any links for compressor maps for the holset range.
cheers dude
cheers dude
Colonel Sanders
- Le Surrender Monkey.
- Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
wich is the better turbo for an e30, hc1, hx35 or hx40??
