does anyone know of a big front mont intercooler to fit on my car, apart from the rs500 one cus kos told me i would have to loose the two inner lights for that to work.....
any suggestions? or otherwise i will have to get GRS to make me one....
big intercooler
Ant
- Retired Team Member
- Contact:
twinnned cossie units dude !, use two cores , one on top of the other and have new tanks made to suit , or....
I can supply a unit 70% larger as per the "racecar" thread Kev.
What are the charge temps like ? ambient + ?? on full throttle/boost ? , its not always the IC thats at fault, a compressor outside its efficient range will pump a lot of heat into the intake charge.
Email FTW
- fowler
- Boost Junkie
- Contact:
as ant says the racecar one is a good one to get. a very good price aswell can i have mine cheaper please now ant free plug LOL
EX A-Tech Workshop bitch !!!
gone but not forgotten
Don't get one made until you've had a good poke around a scrapyard for one midnight. Check out Volvos and light commercials like Sprinters and Transits for intercoolers. You should find a whole load of different shapes and sizes in any half-decent scrappie for a lot less than it'd cost to get one made.
Turbo-Brown
- Boost Junkie
- Contact:
Ooh, you got any piccies Ant?
what size comparrison is the IC pictured to the RS500?
I will require an IC for my S14 turbo project.
Toby
1987 E30 M3 S14 Turbo
1971 V12 E type Roadster
Ant
- Contact:
true, but its far more efficient Kevin
the fins are stacked alternating to make the surface area 2X the frontal area.
BTW, thats the A-Tech "small" intercooler. there are 2 more in the range, 2X that one and 3.5X that one.
Email FTW
