m20 manifold on a m30 can it be done
savvi
Thu Mar 29, 2007 12:16 pm
im thinking about putting in a e34 3.5 motor in my 325i sumtime this year but the intake manifold on the 3.5 is on the opposite side ,
can i put the m20 manifold on the 3.5 as i have a cold airbox already fitted to the m20 and it works realy well and would like to keep it that way,other wise ill have to make another one up, in my oppinion i dont see why it wouldnt work, any comments welcome
thanks
[/img]
Toby_Unna
Boost Junkie
Thu Mar 29, 2007 12:24 pm
won't work
you can move the throttle body to the other side of the E34 manifold easily however.
savvi
Thu Mar 29, 2007 2:29 pm
can you please b a bit more specific on how to do this to the e34 manifold, and why wont a m20 manifold work
thanks
Toby_Unna
Boost Junkie
Thu Mar 29, 2007 2:55 pm
the m20's ports are closer to each other; the whole engine is shorter.
savvi
Thu Mar 29, 2007 3:01 pm
thanks for the pics this looks like a good way of going about it,
is it a easyish conversion 2 do
Toby_Unna
Boost Junkie
Thu Mar 29, 2007 3:08 pm
all you really need to do is machine the left face (with the 3.5 lettering) flat, put the hole in (i used a drill and file, the metal is thin), drill and tap holes for mounting studs, make up a blanking plate for the old hole.
i think it looks much better than the standard setup.
only thing is, if you're still using the standard AFM there may be little room for it?
eko
Old timer
Thu Mar 29, 2007 3:32 pm
Toby_Unna wrote:Image
Must say Toby im impressed :cool:
savvi
Fri Mar 30, 2007 1:27 am
what about engine mounts do i need to get some fabricated up
jaffro
Tue Mar 11, 2008 7:41 pm
jaffro
Tue Mar 11, 2008 7:50 pm
how are the breathers re,routed when doing this
