3.64 LSD into M30 335i ??
TheConverter
Post Sun Mar 18, 2007 3:10 pm
Was hoping for a 3.46 but to keep costs down i am using a 3.64lsd, was going to tune her up to bout 245hp also but if its too much for a 3.64 i will keep it standard...... Anyone out there using this diff? anyone know if it will be an ok drive with it in?
chu346
Post Sun Mar 18, 2007 6:36 pm
should be fine, i think ant said he was using that ratio on his old turbo car running around the same amount of power.
oldroydsr4
Post Sun Mar 18, 2007 6:41 pm
i think the diffs are good for approx 350-400nhp
Andy335Touring
Post Sun Mar 18, 2007 8:01 pm
Should be fine to start off with, see how you get on with it ?
fuzzy
He who sleeps with "Gingers"
Post Sun Mar 18, 2007 8:06 pm
i know this diff will be slower accelerating but quicker top end but how much of a difference will it actually make compared to a 3.91 lsd?
jonb
Post Sun Mar 18, 2007 8:36 pm
This is the best diff to use.
The 535 had this ratio as standard.
gareth
Post Sun Mar 18, 2007 9:29 pm
jonb wrote:This is the best diff to use.
but with much bigger tyres...
kabeer
Post Sun Mar 25, 2007 3:56 pm
i'm using a 3.91. just got it today. but some drive shaft problems to sort it out to see the real potentials from 3.91.
post it later
cheers :D
Proud to say, First E30withM30 in Kuwait.
maxfield
Post Sun Mar 25, 2007 3:58 pm
fuzzy wrote:i know this diff will be slower accelerating but quicker top end but how much of a difference will it actually make compared to a 3.91 lsd?
Not much but you might be able to tell
