325i Touring v8 swop
primeevilcars
Sat Mar 17, 2007 9:48 pm
hi and welcome
looking round came across a accdent damage m reg 530i for 200 quid engine is a very sweet v8 i drive a e30 325 tourer and wanted to know how hard is the converton and does anybody have wiring diagrams and other bit of info that can help me in doing this job
phoe
ed325i
Sat Mar 17, 2007 9:52 pm
Hi, Welcome to the zone.
Look here >> http://www.e30zone.net/modules.php?name ... ic&t=47883
I found a 540 today 8)
primeevilcars
Sat Mar 17, 2007 10:07 pm
ed325i wrote:Hi, Welcome to the zone.
thanks for the link
you using the 540 for a project.
also here is a pic of the v8 removed
it came with a manual box aswell
jonb
Sat Mar 17, 2007 10:47 pm
Its alot of work fitting those engines in an e30.
The fact that it is a 3 litre makes it a bit pointless. They are around 220bhp as far as i know.
If your going to do it then stick the 4 litre in.
bigdek
Sat Mar 17, 2007 10:51 pm
primeevilcars wrote:hi and welcome
phoe
Bargain m8 .
the gearbox is worth twice that :cool:
Sat Mar 17, 2007 10:55 pm
I agree with Jon, get yourself a 4 litre if you want to go to the trouble of fitting it.
You allready have the manual box so at least the 3 litre wasnt a waste :)
3 litre = 218bhp 229lb/ft
4 litre = 286bhp 295lb/ft
No contest really
nickso
Sat Mar 17, 2007 11:49 pm
i agree....keep the box and find a 4.4 litre to fit instead
'88 e30 328i M52 track bint.
primeevilcars
Sun Mar 18, 2007 9:04 am
thanks for all the advise will see if i can find the 4 litre befor i junp in and strip my 325.
also i have a eaton 62 supercharger would the 530/540 engines handle this type of chargre or is it a complet rebild with uprated pistions crank etc.
thanks phoe
m-dtech
Unapproved Trader caution
Sun Mar 18, 2007 6:54 pm
For that kind of money, would you be upset if the engine went pop ?
bigdek
Sun Mar 18, 2007 7:12 pm
you can run 6 psi ok which will give you just over 400 bhp .
Dont think their is space for an eaton but could squeeze in a more compact centrifugal type
Stripping these engines are big bucks . Around 600 notes just for gaskets 8O
primeevilcars
Sun Mar 18, 2007 10:22 pm
bigdek wrote:you can run 6 psi ok which will give you just over 400 bhp .
so 6psi that better than i was thinking and if i get close to 400hp i be really happy it would make fitting the 3litre alot less of a wast of time especially now i just sold the lethers and alloys for 400quid so the engine cost nout and i am 200quid up and still alot of car left to sell.
make cars fast BUT also make them look good!
e30 325 tourer
legasy twinturbo
one off legacy turbo showcar
200sx s14 drift project (destoryed)
320 cab (gone)
325 cab (gone)
bigdek
Sun Mar 18, 2007 11:03 pm
400 is with the 4 litre .
primeevilcars
Mon Mar 19, 2007 12:08 am
bigdek wrote:400 is with the 4 litre .
so i would be looking at about 300hp on the 3 litre rufley depending on psi etc.
e30 325 tourer
legasy twinturbo
320 cab (gone)
325 cab (gone)
m-dtech
Mon Mar 19, 2007 10:42 am
even as standard the 3.0 v8 in the e30 wont be slugglish.
> 200bhp is plenty much fun.
primeevilcars
Mon Mar 19, 2007 3:21 pm
i've desided to fit the engine.
can i use the 5 series diff and prop or are the 325 ones on my car ok to use
jkarran
Mon Mar 19, 2007 3:52 pm
Good plan, fit the bargain engine and get V8 :cool: . Easy upgrade to 4L or 4.4L in the future :D
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
primeevilcars
Mon Mar 19, 2007 4:14 pm
jkarran wrote:Good plan, fit the bargain engine and get V8 :cool: . Easy upgrade to 4L or 4.4L in the future :D
jk
got it in one jk especially as engin and box now have cost me nout.
e30 325 tourer
legasy twinturbo
320 cab (gone)
325 cab (gone)
primeevilcars
Tue Mar 20, 2007 10:22 am
can anybody tell me if this is right for the wiring for the engin install
E30 ------------------------------------- V8 engine
blue 1 ---------------------------- 25 blue (generator)
blue/black 2 ---------------------- 1 blue/knows (oil level statically)
brown/violet 4 ------------------- 11 brown/yellow (coolant temperature gauge)
black/brown 5 ------------------- 23 brown/green (oil pressure)
green/yellow 6 ------------------ 22 green/knows (diagnosis river
green 7 -------------------------- 21 green (ignition unsecured)
yellow/knows 8 ----------------- 24 black-and-white/(consumption gauge)
black 9 -------------------------- 20 black (tachometers)
violet/green 10 ------------------- 2 blue/yellow (oil level dynamically)
knows/blue 11 ------------------ 19 knows/green (Diagn. Service interval)
violet/red 13 -------------------- 13 green/violet (gasoline pump)
blue/yellow 14 ------------------ 16 knows/yellow (ABS diagnosis)???
black/green 15 ----------------- On mass
black-and-white/ 16 ------------ Tachosignal?
black/yellow 18 ----------------- 18 black/yellow (starters)
red/yellow 20 ------------------- 3 Red/knows
thanks phoe
e30 325 tourer
legasy twinturbo
320 cab (gone)
325 cab (gone)
bigdek
Tue Mar 20, 2007 5:12 pm
check your hotmail dude :D
primeevilcars
Tue Mar 20, 2007 9:03 pm
bigdek wrote:check your hotmail dude :D
your a star bigdek :D
i am of to workshop in the morning to get started.
also bigdek ive been reading your thread and do you have any pis of the work to be done on the tunnle for the box to fit
e30 325 tourer
legasy twinturbo
320 cab (gone)
325 cab (gone)
bigdek
Tue Mar 20, 2007 9:05 pm
none rqd m8
primeevilcars
Wed Mar 21, 2007 10:05 am
bigdek wrote:none rqd m8
:cool: that mikes life esaser
e30 325 tourer
legasy twinturbo
320 cab (gone)
325 cab (gone)
