It was always my intention to perform this April, however my hand has now been forced because my head is cracked - this means I have to start this on Saturday.
As with any conversion like this i'm sure it's always easier in theory than in practice, so guys I need some serious advice.
The car in question is a 325i touring, manual 1989 model, the donor car I have is a 1992 E36 325i coupe non-vanos model, I have the whole car so any bits needed from the E36 can be instantly sourced for this purpose.
I have many questions but don't really know where to start
I intend to use the E30 gearbox, as I understand it this can happen if a certain amount is taken from the flywheel, how much needs taking off and from which side? or if I decide to use the E36 gearbox what are the implications of that?
What sump do I need? is it an E34 M50?
What about cooling, which rad can I use?, am I able to retain the viscous fan or will I need to put an electric one on?
What route is needed as regards to the brake servo?, why do you need to change it, purely for clearance issues because of the larger cylinder head?
This I feel is just the start of it, basically i'm hoping for specific answers to my cause, there are many more questions like electrics, heater pipes etc. but this will start the thread and at least get the ball rolling for me.
Your help would be very much appreiciated(sp?)
