2.7 supercharger build pix - test run vid uploaded
racecar
Post Tue Feb 27, 2007 12:18 pm
finally making progress:
this is where its going to be located - similar to lennie's i think
we are still working on bracketry and getting heads round suitable belt tensioner mechanism
alternator has been switched to other side - with a bracket with drilled holes in!!!! - must save half a ton! :) - gotta re-route cables - which i'll do this week one evening when its not dreary outside - probably going to need to extend cable
waiting on news re availibility re one of lennie's old 6.5" pulleys - nose of m90 = 10 rib think lennies pulley is 6 or 7 - if no longer available have a mate coming into office tomorrow and i'll bring a spare crank pulley in if i can find one to use as a base template
sourcing a fan belt just slightly smaller than stock for alternator - which we can then suss out belt tension adjustment etc. probably will get some bling hose with lovely push on connectors to replace oil cooler pipes
other stuff to do when physical brackets/tensioners made = pipework - have some nice agricultural plastic drainage pipe for template - + intercooler stuff - belts for blower + visit to A-tech for mapping and watch it go bang after 5 mins
WILL be ready mid april - ha ha :)
Ant
Retired Team Member
Retired Team Member
Post Tue Feb 27, 2007 12:22 pm
Looking good Ross/David :thumb:
can you not spin the oil filter take off 180' to assist ? will move the O/cooler take off backwards and away from the Alt maybe ?
racecar
Post Tue Feb 27, 2007 12:27 pm
ant
thats a good plan! - will try that! it was getting late afternoon on sunday and pubs were beckoning - i'll look at it tonight - phone you later dude
ross
dark_sounds
Post Tue Feb 27, 2007 12:48 pm
isnt a 2.7 high comp? F.I needs low comp?
what have you done to low comp the engine??
looking good so far :)
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
Ant
Retired Team Member
Retired Team Member
Post Tue Feb 27, 2007 12:57 pm
Ali, the engine was built 9:1 CR with the Charger in mind from the outset
you can boost a high CR engine, not an issue but the max boost threshold will be lower
dark_sounds
Post Tue Feb 27, 2007 1:19 pm
interesting :)
so out of interst, what was involved in creating a low comp 2.7? what kind of work?
whats the comp ratios on a standard 2.5 and standard 2.7? just to compare.
racecar
Post Tue Feb 27, 2007 4:59 pm
it was v frustrating building a low comp 2.7 with boost in mind and then running it n/a for a year - well ok it's only probably done 3 trackdays!
low comp bottom end in this case = m20 block not decked as much as you would for optimum n/a c:r
however not sure anyone has used eaton m90 on a m20 yet? - lennie the pioneer on all this kind of stuff used an eaton m60 i believe from an slk - whereas this little bad boy comes off a db7 and should run a decent amount of boost - well hopefully more than those ebay electric superchargers anyway.... :cool:
jkarran
Post Tue Feb 27, 2007 6:02 pm
racecar wrote:...this little bad boy comes off a db7 and should run a decent amount of boost - well hopefully more than those ebay electric superchargers anyway.... :cool:
:teehee: I suspect you'll manage that. 1500cc/rev into 2700cc engine is more than 1bar with 1:1 pully ratio, are you going for big boost with an IC?
<edit>Of course what I meant was 2:1 pully ratio :o: </edit>
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
racecar
Post Tue Feb 27, 2007 7:18 pm
yeah to make it worthwhile and justify the low cr build - reasonable boost is expected and the M90 specs mean that with a "little" engine to feed - the blower will not be operating past it's efficiency range - m90 is aimed at 3.0-5.0 lumps and has double the capacity of the m45 which seems to be ok on smaller 4 pots
IC has just been ordered from ant which will be fitted on mapping day
just found out that i can get a 2nd hand OE "vane edis pulley?" from an aston parts dealer with the correct 10 ribs
to match the nose pulley on the blower - for about £50 - which WILL be made to fit onto the existing pulley - should save some time!
Apal
Post Tue Feb 27, 2007 7:55 pm
To clarify boost and pulley sizes. The 2.7 needs to draw (without any super/turbo charging) 1.35Lts of air per crank revolution, assuming 100% volumetric efficiency. So the M90 will only be delivering an additional 0.15Lts of air to the engine with a 1:1 pulley. Which is an additional 11% and therefore 0.11 bar of boost above atmospheric (ie relative).
We are talking fixed displacements therefore increasing the amount of air being forced into a fixed volume will increase the pressure by that ratio (adiabatic being assumed). As 1 bar is approximately 14psi this equates to 1.6psi.
On this basis a 2:1 pulley ratio will deliver 3Lts of air per crank revolution giving a theoretical pressure of 3/1.35 = 2.2 bar absolute therefore 1.2bar relative 16.8psi.
jkarran
Post Tue Feb 27, 2007 7:57 pm
What boost do Aston run? You'll need to scale it M20B27_boost = Aston_boost(Aston_capacity/2700) if you plan to run the standard AM crank pully.
I'm fitting M45 to my 998cc Yamaha engine.
jk
jkarran
Post Tue Feb 27, 2007 8:03 pm
Apal wrote:To clarify boost and pulley sizes. The 2.7 needs to draw (without any super/turbo charging) 1.35Lts of air per crank revolution, assuming 100% volumetric efficiency. So the M90 will only be delivering an additional 0.15Lts of air to the engine with a 1:1 pulley. Which is an additional 11% and therefore 0.11 bar of boost above atmospheric (ie relative).
:chuckle: You are of course right. Put that down to end of day brain failure! I rounded the engine size up to 3L, divided by two to give 1.5L. M90 gives 1.5L/rev you're quite right M90 on 100% efficient 3L engine gives no boost, not 1bar. MUST THINK HARDER :chuckle:
I'll edit my post.
Apal
Post Tue Feb 27, 2007 10:11 pm
Good point jk re Aston boost pressure and relative cc of both engines. Simple but effective way of getting things close without too much head-work. I'll get Ross to find out from his HWM friends.
jkarran
Post Tue Feb 27, 2007 11:46 pm
I wrote a spreadsheet that takes most of the relevent factors and calculates boost and temp rise/drop at various parts of the system for M45. It also calculates crank pwr, available crank pwr and a whole load of other bewildering numbers :chuckle: If anyone wants a copy then I'm happy to share it. Could also be addapted for M62/M90 or any other positive displacement blower if you have:
pwr input vs rpm curves
temp rise vs rpm curves
probably something else that escapes me at the moment :roll:
If there's a way to host it here then it's free to a good home :D
jk
jkarran
Post Wed Feb 28, 2007 12:07 am
jkarran wrote:What boost do Aston run? You'll need to scale it M20B27_boost = Aston_boost(Aston_capacity/2700) if you plan to run the standard AM crank pully.
jk
:o: My maths is shit today! that'll get you a ball park figure but this will give you a better answer, my brain's really letting my mouth down at the moment :? I'ts done in two steps.
Step 1: AstonPullyRatio = ((AstonBoost+1) x AstonCC) / (2 x M90CC)
so say Aston boost is 0.6bar on 5L engine:
AstonPullyRatio APR = ((0.6+1) x 5000) / (2 x 1500) = 2.67
Step 2: M20B27 boost = ((APR x 1500) / (2700 / 2)) - 1
IF the example figures are close for the Aston (a total guess) engine that's 1.96 bar boost on the M20b27 :eek:
jk
jkarran
Post Wed Feb 28, 2007 10:11 am
:o: Or simpler yet correct... M20b27_PR = AM_PR x (AM_CC / 2700)
Where PR is pressure ratio. Just use (boost + 1), units of boost must be bar.
Wasn't having a very clear thinking day yesterday :o:
jk
Apal
Post Wed Feb 28, 2007 10:19 am
Thanks for the maths lession jk. Also would appreciate a copy of your blower calcs spreadsheet as a sstarting point re the m90. Possible to pm...?
jkarran
Post Wed Feb 28, 2007 10:29 am
I think it's me that needs the lesons :chuckle: PM me your email address and I'll send it on to you. You'll need to addapt it but if you have the data on the M90 I can maybe do it quite quickly.
jk
Apal
Post Fri Mar 02, 2007 6:44 pm
Bit more progress today with the fabrication of blower mounting brackets on the spare block. Should have the alternator working in its new position this weekend so another step closer.
Apal
Post Fri Mar 02, 2007 6:48 pm
Any ideas why the image does not display?
sam325is
Post Fri Mar 02, 2007 6:59 pm
http://shutter14.pictures.aol.com/data/ ... SP0280.jpg
you cant use [img] on a whole gallery you need to use links to single picture like the one above, you can get the link by getting the picture in large and then you right click on it and go to properties and then you copy the address from there
Apal
Post Fri Mar 02, 2007 9:19 pm
Thanks for that - next 'obvious' question - how do you make a picture appear in the body of a post?
BigPerformance
Post Fri Mar 02, 2007 9:34 pm
If you send it to me I can host it for you. :cool:
Apal
Post Fri Mar 02, 2007 10:08 pm
Not worried about the hosting, its the command/syntax to embedding a pic in the post as opposed to a link.
jkarran
Post Sat Mar 03, 2007 12:29 am
Apal, try photobucket. There's an img button you click once you have uploaded your pic, it puts the string you need on the clipboard, all you need to do is hit ctrl-v to put the pic in your thread.
I think the hosting comment related to the blower spreadsheet I offered :?
jk
racecar
Post Sat Mar 03, 2007 11:06 am
jk
can you email the blower spreadsheet to ross AT racecar DOT co.uk?
thanks!
we are working on it this afternoon - and trying brackets that have been made on dummy block on car. understand that the blower takes 40hp to run at 12k - so we are keen to make it "stout" - also alternator will be set up/cables moved etc
on another note gonna order a grp bonnet from taffy next week - which will save some weight but crucially make it sooo much easier working on it
- vane edis pulley thing did n't work out from parts place - we will be aiming for a 2:1 drive ratio i think
- getting a mate to "shadow graph" the pulley on the nose of the m90 - and then he will make to diameter we want
from another post on here - can't remember who - just got "Supercharged!" by Corky Bell - looks as if it's a good read!
ross
Ant
Retired Team Member
Retired Team Member
Post Sat Mar 03, 2007 9:26 pm
Andy335 was kind enough to lend me both Corky Bell "bibles", they were an excellent resource, to my shame I had them almost 2 years I think, sorry again Andy :cheers:
bottlecapE30
Post Thu Mar 15, 2007 2:11 am
I'm working on a supercharger build with an m90 on my 2.7l as well http://www.e30tech.com/forum/viewtopic.php?t=30929
i can tell you the Corky Bell book is worth the read a lot of info.
Looking good :thumb:
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
racecar
Post Thu Mar 15, 2007 9:53 am
bottlecape30 - thats a good read on your project - i can see you have the finishing tape in sight - keep it up!
first pix of pulleys from MDTS :
MDTS made 2 pulleys for me 5" and 6" - made out of billet aluminium and hard anodised - look v factory :cool: - tough as steel and half the weight
any of you boys on m20's want similar - speak to mike:
01329 829388 - looking around £100 - although mike can do all sorts of one off stuff - he's a car head - building a 350 CI small block powered cobra replica 8O
reckon we'll have blower on + piping ready for 1 st week in april!
Demlotcrew
Post Thu Mar 15, 2007 9:56 am
OT but can these guys make me a overdrive pulley for the water pump and power steering?
Andrew
racecar
Post Thu Mar 15, 2007 12:55 pm
andrew
yes i am sure of it they mainly do trick marine engineering proto stuff - but think mike is keen to do more car stuff
if you can send dimensions will help - i'd give mike a call and ask the question - i can say that the workmanship is shit hot!
ross
bottlecapE30
Post Sat Mar 17, 2007 5:47 pm
wow those pulleys look great. that is some top notch work
racecar
Post Mon Mar 19, 2007 9:14 pm
tensioner pulley just been made - good work david!(Apal) - then gonna be anodised + shaft being made tomorrow - by the end of the week all bracketry will be ready for trial fit to engine in car.
once trial fit done on saturday - they will be taken off to be painted/finished off
hopefully intercooler will arrive this week ready for install/move oil cooler etc - then subsequent pipe creation. was due to drop car off to btb for the weekend for the pipes to be made up - but running out of time now - so probably will make pipes as tem fix out of suitable flexible hose and then make metal pipes after if there is time. when pipes are made - they are going to be tapped for temp sensors before and after i/c + provision will be made for water injection. thinking of creating an alloy tank in spare wheel well with this in mind...
also hks ssqv blow off valve + boost gauge etc has arrived and on a non-mechanical note - at the weekend bought some pimp rims off the 'zone - 15x8 deep dish - just fitted some new toyo r888's - so ignore tyres in pix
bottlecapE30
Post Wed Mar 21, 2007 12:41 am
Comeing along nicly. Those wheels are the tits :cool:
racecar
Post Fri Mar 23, 2007 7:21 pm
Ok - we got it running - without pipes - so really just a test of mechanical pulleys/brackets - but it sounds cool!
Click below for first run vid (top one on page):
http://www.etribes.com/video/gallery/73127
http://www.etribes.com/sites/etribes.co ... review.jpg
pic of install
20 mins later blower and bracket removed - all bracketry to be painted/idler pulley to be anodised - i/c arrives next week - oil cooler to be relocated higher up - then i/c fitted - then we play with pipes to connect it all up/add SSQV etc - then off to ants for map etc - we'll run 5" pulley for start - then think about switch to 6" - takes minutes to switch!
random pic of finishing up
new pimp rims fitted!
off to pub now to bore everyone about it - big up to david c for cool fabrication work - brackets etc fitted first time![/img]
