I was pulling a B20 flywheel from a engine, and yesterday I was pulling a m10 flywheel from a B18 engine,
I was looking at them and they are identical in size in regards to diameter and ring gear diameter
the only diffrence is the mounting points for the 218mm pressure plate are a little closer to the center then the B20 one, wich is on the edge really,
This means that if the 228mm plate fits inside the M10 trans that any BMW 228mm setup will work, that means all 325i setups as well,
Just another option if a M30 trans isn´t available,
Flywheel discovery M30 - M10 trans related
Gunni
ed325i
So a m10 gearbox will work a m30 engine ??
m-dtech
- Unapproved Trader caution
yeah it will mate
- Homo Hair
allows you to use a standard m10 prop as well iirc
Gunni
I´m not sure on the prob, but I used a M20B20 one,
it fit perfect
it fit perfect
m-dtech
would be interesting to know the length of m10 prop...Jhonno wrote:allows you to use a standard m10 prop as well iirc
e30Alex
ive got one complete of the car.if i can find a tape measure right now i will measeure it......
Im a two car man. Shame my bike gets used more.Damn the MOT!
e30Alex
.......found a tape measure.....1571mm.please tell me it fits and i have all but engine and mounts!Alex
m-dtech
thats same as 318i
too long mate.
too long mate.
e30Alex
do you know the length of a 320i prop?
Prop lengths are shown on the ETK, and, I think, on realOEM as well.
charlE30
E30 320 prop is 1526mm according to the ETK
Charlie
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
