316i gearbox fit onto 318iS??
Rupe30
Post Mon Feb 05, 2007 1:10 pm
Hi just bought a 318iS engine but without the gearbox, just checking, will my 316i gearbox bolt on?? theyre M40 engines.
Cheers!
Rupes
E30Mark
Post Mon Feb 05, 2007 1:41 pm
This has been discussed before! can't remember the outcome. You'll need a 318is prop which makes me think the gearbox is different...
PM for details
Chris-W
Post Mon Feb 05, 2007 3:53 pm
Part numbers are different, but can't say for sure about fitments.
Re the prop - isn't that a length thing as the M42 sits further back?
If you can't use it and struggle for a 318is 'box, let me know.
Rupe30
Post Mon Feb 05, 2007 7:12 pm
theres a guy selling his 318is box 4 £50 its done 120,000 miles, sound alrite? can u get me a better1 chris?!
Chris-W
Post Mon Feb 05, 2007 7:16 pm
Same miles, same price :)
m-dtech
Unapproved Trader caution
Post Mon Feb 05, 2007 9:24 pm
same bolt pattern the difference is a big rubber doughnut that joins the prop to the gearbox.
measure the distance from the m40 engine mount hole to rear of engine and also measure the distance from m42 mount and rear of engine, if both the same then you have no problems.
hth
Rupe30
Post Tue Feb 06, 2007 3:50 pm
so anyone know if it will deffinately fit or not!? no1 done it before?
Demlotcrew
Post Tue Feb 06, 2007 3:58 pm
m-dtech wrote:same bolt pattern the difference is a big rubber doughnut that joins the prop to the gearbox.
hth
The rubber coupling is the same for all E30 cars (except M3, 320is and IX models)
The difference is the gearbox output flange is quite a bit longer on the M42 box and some of the internals are different (stronger)
I have a mint 318is/M42 30k miles box for £100
Andrew
m-dtech
Post Tue Feb 06, 2007 5:41 pm
i have prop and gearbox here you can have for £100
you will prob need gear linkages aswell.
Rupe30
Post Mon Feb 26, 2007 5:07 pm
will i need the prop then? how many miles has ure box done 'm-dtech'??
Theo
Post Mon Feb 26, 2007 7:41 pm
I also have an m42 prop and a very good gearbox. Where are you based?
Rupe30
Post Tue Feb 27, 2007 11:09 am
Theo325 wrote:I also have an m42 prop and a very good gearbox. Where are you based?
In Stratford upon Avon, how many miles has the box done??
Gunni
Post Tue Feb 27, 2007 11:23 am
The diffrence between the two boxes is the output flange,
the M42 one sticks out a little bit far back then the M40 one,
by changing out the flange you can use your M40 driveshaft or vice versa..
Gunni
@ 2012 VEMS group buy !!
Theo
Post Tue Feb 27, 2007 2:37 pm
I'm based in Kent, so quite a long way to collect. Mileage is 160k - but a very good box, also £50.
Rupe30
Post Thu Mar 01, 2007 6:50 pm
so your telling me i need to get an m42 (318iS) box but if i swap the `flange`over (not sure which part you mean???) i can mate my 316i propshaft to the 318iS box? :?
Gunni
Post Thu Mar 01, 2007 7:50 pm
the flange is the unit that bolts to the driveshaft from the gearbox
by looking at the two you´ll see the diffrence right away.
Gunni
Rupe30
Post Thu Mar 01, 2007 8:28 pm
rite so just got to get a 318iS box then and swap the flanges over, wkd cheers guys.
